Upgrading half shafts
I've been thinking I need to do some upgrades on my driveline before I go to wider rims and tires with my 406 and have often heard of changing over to BB half shafts as a first step. What exactly is involved with that change?
And what becomes the next weakest link in the chain...or fuse as it were?
Received 6,943 Likes
2015 C2 of Year Finalist
The biggest thing with BB half shafts were caps that were bolt in instead of the straps.
You'd have to disassemble the diff to replace the yokes. The 'BB' shafts themselves are identical to 'SB' except for a bit of shot peeing at the end welds.
Not worth the effort.
Received 1,875 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
The first thing I've always seen break if it happens to hook up is the outer stub shafts. I've seen it happen on relatively mild 327's with BFG street radials. Replacing them with good aftermarket axles (Tom's or equivalent), while not quick and easy is a good plan.
But before doing that, I'd install solid Spicer U-joints.
The halfshafts hold up pretty well usually.
JIM
JIM
Thanks Scott, that's encouraging although all the horror stories and pictures of damage inflicted by broken half-shafts still worries me.
Thanks Jim, is there any downside to solid U-joints?
I went with all Tom's parts. As stated before 30 spline spindles, new larger half shafts and inner 30 spline stub shafts with 30 spline spider gears and a 1350 joint Denny's driveshaft and an Autogear M22W 4 speed.
rgds
I believe that usually the damage from a loose half shaft results from a broken U-joint and not the half shaft itself. That is what obviously happened to the underside of my car before I bought it. However, I also found the half shaft on that side was twisted a number of degrees because the two yokes were no longer in 90 deg phase with each other. That and a few posts/pictures of twisted in two half shafts over the years have demonstrated this also happens from time to time.
