If you built a Frankenstein Midyear...
Which OEM parts of the whole of each year would you use? The restriction is it has to be original from the factory, no aftermarket.
I would use...
Body & Trim:
1966 coupe (since it lacks roof vents)
1963-64 side vents cut out like the Grand Sports
1965 396 engine hood with the bump and side "vents"
1963-64 grill
Paint: 1963-64 Daytona Blue
Engine:
1964-65 L76 365 HP solid lifter engine
Trans.:
4 speed Muncie close ratio
Rear:
3.70 posi
Interior:
1964 interior (all of it: gauges, glove box, doors, seats, console, carpet)
I would use...
Body & Trim:
1963-64 grill
Engine:
Trans.:
Rear:
3.70 posi
Interior:
While we're dreaming, why not '63 back windows and FI, and maybe some KO wheels?
+1 on '64 gauges, absolutely the best!
But thumbs down on stock '64 seats, oh, my achin' butt! I prefer C4 and newer in a C2.
If I did it again, I would do it exactly as I did it.
Use the '64 as a basis and establish a dominant pattern. Then take the pieces from the other years, as appropriate to support the pattern. For me the dominant pattern was the "ribs" as seen in the grill, vents, rocker moldings, etc. The pattern carries from ribs to the ridges in the instruments (similar).
So I added polished aluminum side vents (ribs) to the cut-out coves, ribbed rockers from the (IIRC) '66, LT-1 valve covers with painted in/polished ribs, etc.
Then when I developed the Header Power Bracket, I came out with a ribbed version to carry the theme.
The interior is also ribbed in the upolstery and even headliner.
But then there is that '67 hood that just looks so nice.
I wouldn't need a Frankenstein!
Having nothing to do with value just the mid year I would like to drive the most:
'67 Coupe - Marina Blue - white stinger - white and blue interior
L88 (because aluminum heads and single 4 BBL) - 4 Speed - 3:36 rear - big brakes - big tank
63' SWC-Grand Sport
Building one of a sorts: 63' SWC GS
1963 Split Window coupe reserected from a dismal grave.
68' doner frame convertid back to a 63' frame specs.
All origonal 63' suspension. Considering upgrades to disc.
327 ci with 340 camel humped heads, Moon cross ram intake with four weber 45 DCOE's and old school MSD tach drive distributer.
2sp PowerGlide with a 308 rear
All 63' interior with origonal $$$$ trim.
GS fender flares with Halibrand GS rims.
Datona hood with custom heavy duty louvers
All parts and I mean "ALL" customized to fit together.
"Corvette" = French word meaning "does not fit".
19 years and counting, maybe I'll get to drive it this year
I would probably start with this and then
And add the 377 Cubic inch Grand Sport engine and the tube chassis and somehow get more tire under it, so as to not ruin the pretty body lines! I would probably cut it in half, widen it so I could drop it down over the wide tires and lower it if the lower profile tires aint enough! I definitely if I did that, would have to fab up a new hood!
A guy that wondered into the wrong thread!
My Frankenstein!
Frankenstein with a small block? What's up with you guys. Frankenstein's monster needs POWER.
http://www.ultrastreet.net/engines/540_ultrastreet.php
This article says, "This 377 cubic inch small block was fed by four 58mm Weber carburetors through a special aluminum cross-ram manifold. The engine was said to produce 485 horsepower at 6000 rpm."
Yeah, I'd call that inadequate, considering an out of the box L88 would make 550, never mind the crate motor linked in my post
No, then it would be a kit car and not a Frankenstein build!
Get it all together, and then get out the two jumper cables, alligator them to the battery posts and give good ole Frank some juice!!!!!!!!
On other Forums there has been a movement like with the Porsche crowd to adopt bastard builds and name them Outlaw (for the 356 crowd) and for the 911 crowd (they are nicknamed Renegades). Thus for our beloved Corvette--- should we grab a name before the rest of the Marques have claimed them all? Thus we can formalize "Frankenstein" build formally now. We are stupid and let the uppity crowd coin the Resto-Mod term, etc.. I would personally rather call someone's Frankenstein what it is- Frankensteined!!!!!!
Does anyone second the motion?????
The proverbial Big Block vs Small Block conversation!
http://www.grandsportcorvette.com/gs/
With the way flared cars are treated by my favorite NCRS people and such, my beltline flared car with race and aftermarket parts mine as well call anything flared a Frankenstein build, and I would be proud to wear the name. I am also a Herman Munster show fan! Cool cars in that series! The original Frankensteins!
Ah yeah! The Munsters! I love em too. As Grandpa Munster said in the movie, "Munster Go Home", prepping the coffinmobile for the big race, "I took the family car and put in a high lift cam and a blower!" To which Eddie and Herman stomped and shouted, "Yay, Grandpa!!!!"
You can still keep yer puny small blocks. If ya gotta have one, at least get a 454 Motown version....jeez
I hope drawing the comparison between the Munsters and Frankenstein is taken into
My issues with big blocks, isn't that I don't like them or anything because I do! It is that I just like to be able to put down realistic HP/Torque to the street! A big block is a different driving experience than a small block!
The O/P started this thread by saying OEM C2 parts and no aftermarket parts.
While I will gladly 2nd the motion the Porsche guys take from any year Porsche and use aftermarket parts. That really opens things up. I have seen RSR recreations that are amazing. They look period correct except for 17" "Fuchs" wheels and they have later model non EFI engines and 5 speed transmissions as well as light weight body panels (300+ horsepower and 2100 lbs), plus aftermarket suspension and brakes.
Yes they are "Frankensteined" but I don't think with restrictions.
