crank pulleys 3850838 BG & 3744043 BA
Cruise-In II Veteran
Cruise-In III Veteran
What makes and models were each if these for?
I have 66 327/300 a.i.r. Car and need to know which is factory correct for my car.
RED...
69-70 corvette (350) 7 21/64" (OD) (ecx. P/S, C.A.C., H/Per., Sp. H/Per.)
Black
68 Corvette (2nd design) 6 5/8" (exc.C.A.C., H/Per., Sp. H/Per.)
1st design should be stamped, 3747479
Does it show the specs on these related to 66 corvette?
My original (July '66) 300 HP A.I.R. (non a/c) is configured as follows:
Crank pulley 3744043BA.
Water pump pulley 3790356.
Smog pump pulley 3880800.
Power steering drive pulley 3751232BB.
Power steering pump pulley 3770509CE
Alternator pulley 3843342AJ
(There is a crank pulley 3850836 -- used with L79 + power steering. Probably a deep groove).
NCRS ADD THIS CRANK PULLEY PART NUMBER TO THE NCRS JUDGING GUIDE...
Since u have a car like mine. What is the part number on ur water outlet cover. There appears to be 2 types and I need to Know which to use
