67 coupe tire sizes
Received 2,127 Likes
Be safe and and smart, get 205/70/15 radials. Height is very close to stock and will nor through off your speedometer. Dennis
If you want to add just a bit more tire, try the 215-65x15. I have that size on both midyears (both with KO's) and no rub or interference issues. You can swap the speedo driven gear to correct the speedometer, they are pretty cheap to buy. I'm pretty sure you'll find some others chiming in that are running larger tires.
Mike T.
Mike T.
Enjoy while you can.
Received 2,686 Likes
Ohio Events Coordinator
C2 of Year Finalist (stock) 2019
St. Jude Donor '14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
I am running with 215/70/15 w/o any issues for three years now on my '66.
Mike T.
Mike T.
http://forums.corvetteforum.com/c1-a...se-1965-a.html
http://forums.corvetteforum.com/c1-a...-on-66-sb.html
Cruise-In II Veteran
Cruise-In III Veteran
Be careful with wide tires. I'm fixing a cracked fender now from wide tires. I went back to the standard size...
