arp head studs and 1960 corvette stainless
If I rebuild my motor using ARP studs in lieu of bolts for the heads, will the protruding area of the studs interfere with the stainless plug wire shielding or will I still be able to use the shielding with arp studs.
The motor I am building back is actually a 327 L79 clone but dimensionally it is the same at the original 283 except for the possibility of using the arp studs.
