c1 steering box question
I have a question regarding my steering on my 1958 I have the pitman arm disconnected from the steering box
when I turn the steering wheel it's nice and smooth, as it approaches centre I feel a little more resistants then it loosens off for a very very short time and then back to a little resistant, then after it passes center smooth again.
Is there an adjustment to correct this or is this something that has worn?
Wilbur - You're describing the normal way a solid axle Vette's steering should feel. Not to say you don't have some wear involved but feeling stronger resistance at center is correct and normal. If you feel some unusual 'notchiness' or resistance bumps along the way (other than dead center), then there's a chance someone incorrectly adjusted the box and galling or spalling of the sector roller might be happening.
Mike T - Prescott AZ
Wilbur,
I rebuilt my 62 steering box recently. Internals were okay but it needed adjustments to get it back into good working order.
As I understand it, the only resistance (and only slight) should be felt when passing the steering wheel over center/straight ahead. If you have resistance at other times while turning the wheel from lock to lock, you may have some worn bearings and/or gears and shafts.
You can re-adjust the steering box by following the instructions in the Corvette Servicing Guide ST-12 or by referring to videos by Tom Parsons.
Also, may want to check for lubricant. A dry box could cause some resistance felt in the wheel. Originally, the box held 80-90 wt gear lube but more recently, quality axle grease is recommended.
Good luck,
Larry
Good luck,
Larry
Yes I understand that there should be some resistants*at center but what concerns me is the small gap between resistants.
could adjustment be made to fix this gap and how?
Wilbur,
Seriously doubt that any adjustments are going to fix the "gaps" that you notice when turning the steering wheel. Should be smooth with no resistance except while passing center. Also, properly adjusted box with good internals should steer straight ahead without having to constantly re-center the wheel from side to side.
Larry
Larry
Received 1,857 Likes
If you have any roughness or uneven rotation, it's probably a result of spalling on the worm gear (photo below) or on the sector roller that mates with it (good one shown in second photo), or both. You can't "adjust it out" - it requires part replacement.
Wilbur - I think I read too quickly through your opening post. Are you saying that 'besides' the resistance you feel on centerline, once you come off that center point you have some slack and then resistance builds again? It should only be felt on center. If you're sure about where center is located, once you come off that mark you shouldn't find the resistance building again. If you do, that's what I was referring to as 'notchiness'. My 61 had a seriously bad steering box when I bought it. Plenty of lube present but I believe someone tried a shortcut and overtightened the lash screw resulting in my sector roller looking similar to the worm gear in JohnZ's pic.
