Filthy whitewalls
2020 C1 of the Year Finalist - Unmodified
Corvette of the Year Finalist 2018
2017 C1 of Year Finalist
2015 C1 of Year Finalist
Filthy whitewalls
Whenever my 61 gets caught on wet roads, the brake dust causes ugly black streaks on the whitewalls. It seems to come mostly from the vented areas on the wheel covers. Great fun scrubbing them clean again
Did everyone have just have filthy white walls back when most 50's cars had white wall tires and these were daily drivers?
I wonder if the non vented 56-58 wheel covers are as prone to this?
I have front discs and rear drums; There is more dust on the rear tires than the front, but all four produce dust on the white walls daily.
I will try the hose; good idea!
Received 1,295 Likes
2022 C1 of the Year Finalist - Unmodified
2021 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Do you use tire dressing? That will attract dust.
Tire dressing looks great for a little while, but down the road (no pun intended) it's awful.
Bleche White is great for cleaning up the whitewalls, but the warning about it being damaging to wheels is NO JOKE. I got a little over spray on some new aluminum wheels once and it took hours of work to get it cleaned up.
Received 4,551 Likes
2016 C2 of Year
2015 C3 of Year Finalist
Bleche White and a soapy Brillo works great to get them clean. I do not experience the brake dust on my 61 with stock hubcaps. You want brake dust, try the C6 Z06 Of course it stops alot better than the 61.
Based on Diamond back's recommendations; I only use Greased Lightning, water, a small nylon brush and old white t-shirts. They always clean up well.
The problem has been the brake dust.
Just tried Paul's idea of fitting some rubber tubing cut about 4" each to press into the steel wheel vents on the rear; I've heard that's how it was done at the factory. We'll see if there is a discernible reduction in brake dust on the white walls. In theory, most of the dust should stay toward the inner tire wall.
Not sure if they will stay in place or not. Wheel flex might loosen them
Thanks to everyone; I'll update after some driving time next week
Received 1,581 Likes
St. Jude Donor '20-'21-'22-'23-'24
Not much of a brake dust problem on my '67's whitewalls with bolt ons. When the whitewalls get dirty, I clean them with Simple Green.
-- Steve
My 62 with old Torque Thrust wheels shows no signs of brake dust with standard shoe brakes.
My 65 disc brake car has no brake dust either and no full hubcaps.
It could be a function of the type of pads you are using.
Some pads are very dusty and others are not dusty at all.
with ohiovet. My wheels used to be covered with reddish brake dust every time I drove the car, plus they squeaked at slow speed so I switched to an organic pad. While I get a little brake dust, which is to be expected, its NOTHING compared to the old pads. Squeaks are history as well.
I think you guys are right about the new compounds.
My car sat for 40 years.. when I rebuilt the brake system, the shoes looked almost new, so I left the 40+ year old shoes on. I have never even seen a spot of brake dust in 1000 miles.
Probably the asbestos
