Vintage Air Wiring and trinary switch wiring
I have studied the thread on the VA purple wire hook up. It appears that I can hook the purple wire to existing heater brown wire. If agreed should I splice in a additional 10 amp fuse. photo 1
I have installed a trinary switch that also needs switched power and 10 amp fuse. Can I splice this blue/whit wire with a 10 amp inline fuse to the ACC side if the starter switch plug? Photo 2
My understanding of wiring is very limited.
There is no 'purple wire' fuse called for in the VA instructions that I have - and I didn't use one. I suspect that wire might just be a relay signal wire; I don't know why any 'switched' power wire wouldn't work. Why not call VA tech support and find out ???
I called them twice and they were very knowledgeable and courteous.
The main power wire (red wire) should go to the horn relay (not directly to the battery as shown in the instructions). There is a long discussion about this on the Mad Electric web site I won't repeat here. Using this location allows your voltage regulator to properly sense and adjust alternator output, and, your ammeter dash gauge to read correctly.
Al
2021 C1 of the Year Finalist - Unmodified
