Bent Half Shaft Flange. Can it be straightened?
St. Jude Donor '05, '09, '15
It looks like I bent one of the outer flanges on a spare half shaft changing u-joints. I did a search and found I should have used a backing tool or another flange for support when pressing the joints out. I know now. Question is can I straighten the bent flange somehow? Is is possible? Is it reliable.
Tom
Tom
Tom
Tom
Is it practical…………..probably not. Replacements are available, although not exactly as original. Originals can also be sourced if absolutely needed.
I would think that if you only bent and straightened once, you would probably be okay for strength etc. If you bent it a few times, maybe not.
Larry
EDIT: I also remember a machined cylindrical rod with a slight taper on one end has also been used for this. A Driveshaft Speciality shop may have the tools and skill. You could try there.
It is possible. YES. Many years ago Corvette Fever Magazine had an article about this. If you take your time and have a few special tools…..a special hardback fixture (you can buy) and a press. Basically the fixture gets you "close" and then you use the press a little at a time to get final straightness and alignment.
Larry
Larry
Tom
You might even try to Google Corvette Fever and "U-joint and/or Half-shaft joint replacement" or something similar to find the article. I believe Chris Petris was the mechanic and writer of the article. Probably ten years or so ago. I remember it since I was interested in doing this job for my 1967 car and he was able to straighten and re-use a bent flange. Based on the article, I ordered the HD strong back. It worked well for me doing the u-joint replacement work.
Larry
EDIT: FWIW, my car's u-joints and half-shaft joints were the originals. My 20 ton press almost gave up on me before I finished the job.
EDIT2: Super Chevy Parent Company apparently absorbed Corvette Fever. This may or may not be the exact article I mentioned, but it has a lot of the same info. Here is a pic of straightening using a press. http://www.superchevy.com/how-to/cor...pair/axle.html Checkout the full article for additional details and pics.
Received 1,843 Likes
I warped a halfshaft flange once getting a very stuck ujoint apart.
I used a half inch drive strong arm handle through the cup loop to straighten. I just messed with it until the ujoint went together and I couldn't feel any binding at all when working the joint.
If you have any binding, the joint won't last.
Thanks Larry. I will check out the article and I think I will get a "heavy duty strong back". My press is a 20 ton as well. Hope it will handle it!
Thanks Mike. Yeah I can't get the new u-joint in. It won't line up. I bent the flange pretty good. I don't know if I have the "umph" anymore or a bar long enough to make up the difference!. But I'm going to give it a try.
Thanks guys!
Tom
Thanks guys!
Tom
Received 1,857 Likes
Thanks guys!
Tom
Thanks guys!
Tom
Tom
Sounds familiar. I also slightly bent a u joint flange the same way. The fix (if it could be called that) that was used was to remount the u flange back onto the spindle drive flange with the 4 bolts. A small washer was placed in the center between 2 bolts on both sides where the 'bend' was needed. The 4 bolts were then tightened down against the spindle drive flange.
