Speedometer Cable Routing on a '61
Received 3,443 Likes
I've been studying the assembly manual, plus other illustrations on line with no luck. I need to install my speedo cable, and can not find a hole as depicted in the assembly manual to run the cable into the car. My car does not have a hole in the upper trans tunnel area below the wiper motor @ the driver's side, as illustrated. There is a hole right behind the distributor where the tach cable runs thru the firewall, with plenty of room to spare. Does the speedo cable go through the firewall in this area? Once under the dash, it's obvious how it runs, but I want to install it once, and in the right location. Also, my tailhousing has the speedo output on the passenger side....not the driver's side, as the assembly manual shows. Possible wrong tailhousing? The box is an iron cased T-10 that is dated correctly for the car. Any help/pics greatly appreciated!! Thanks............
Received 1,856 Likes
Jeff - this is an original BW T-10 in my '61 before the Tremec swap in. This is how the speedo cable goes... As noted, you have something else going on and will have to adapt your routing accordingly.
Second pic shows speedo cable entering firewall just under the left side of the DS female hood latch and below it through the large grommet
That's the money shot I was looking for. Thanks, guys. I know of a '62 iron T-10 (that I used to own) that has the tailhousing with the speedo cable on the driver's side. I'll have to research it's availability. Meantime, I got the long 61" steel clad cable (the expensive one) and hopefully, it'll be long enough. I did see a hole in the location Frank posted, but mine has firewall insulation behind it, and it looks original and undisturbed. I'll investigate further and get after it. Thanks again, guys!!
