C2 Modern Wiring harness Question
Does any mfg. make a modern wiring harness with new type fuses and labeling on each wire where it connects for a C2. Ideally, it would also have the two piece plug connector at the firewall like the factory. Please advise and thanks in advance as I'm restro moding my 66 Coupe.
Chuck
Chuck
Chuck
Chuck
Electrical is one thing I don't have to worry about. In my case, I couldn't justify buying all repro wiring harnesses - too expensive. I put the money into the drive train and suspension.
American Autowire is supposed to be out with one this year 2015
I don't know of any. I used a Painless 12 circuit system on mine. No firewall connector anymore. Great mil spec wiring system, each wired labeled, modern fuses, master fuse - the whole nine. I even ran the wires for a future upgrade to electric fans.
Snake, I'm doing a frame off resto on my '64 (no A/C and with backup lites) and I'm ready to wire. I'm looking at the Painless system. Refresh my memory please. How many wiring sets are necessary? I thought I remembered 3 coming off. Dash, engine bay, and rear end. Is there more or less? Can I get a complete setup that does it all? Thanks.
It also has wires long enough to wire a school bus.
Got to thinking, also had to remake the wiper switch to wiper motor sub harness. Like I said, you need to be creative or at least competent to duplicate some of the factory sub harnesses.
