Build Thread 63 SWC Resto-Mod Roadster Shop Chassis
Hey Chris,
First all the body work was completed, aligning doors, headlight buckets and then sand, sand & sand. Next, a gel coat was applied (the black layer) and then it is washed off to neutralize it (not really sure about that part). Next, polyester fiber fill primer the gray layer. Greg T. stated most use only one of the layers he uses both to ensure longevity. Then more sanding and when I saw it on Tuesday he was completing the final prime. Lastly, wet sanding before paint with 220, I think, not a body man
Thanks for the reply on media blasting. Yours is exactly how I want mine to begin body work. I will be building the 415 LS3 based motor for my car as well.
j_66chevelle (01-03-2017)
Final Bumper fitting
j_66chevelle (02-11-2017)
If you don't mind divulging top secret info and you know the answer what rate springs do you have on the front?
Bumper fit looks great. This is a very extensive make over and the finished product should be nothing short of fantastic.
Please don't be shy with the updates and pictures.
j_66chevelle (02-12-2017)
#33
Smoke Testing the drive train while paint is being finished
State of the art exhaust system
metal hangers make too much noise
Battery moved the rear
#34
I was thinking about 450 for the front on my C1 but I was afraid that might be soft. Thanks for the reply. Seems almost bad to cover that chassis with a body, it's a work of art by itself. I love the really sharp C2s being built by forum members. Great great work!
#36
Adjusting the tip to fit
Removing the brackets with a plasma cutter
Cutting the bumper in half to move the outside edge in
welding back together, stich weld to avoid warping
Inside brackets
The following 4 users liked this post by j_66chevelle:
65silververt (02-12-2017),
Joe Inama (02-12-2017),
sonksen_design (04-17-2017),
USBillet (03-18-2017)
#37
350 hours to date in paint and body GTS Customs has done a great job, show quality
sealer and base coat
j_66chevelle (04-17-2017)
#40
Nothing short of amazing.
