1967 Corvette pro touring
I thought I'd start a thread here for my Corvette.
Here are some specs on it. The car is street driven and autocrossed
1967 Corvette was a 427 4 speed
now
Gm crate Ls engine 525 horsepower
Legend lgt-700 5 speed transmission by Bowler Performance
Ridetech level 3 Suspension front and rear with Ridetech Triple adjustable shocks
Ridetech Sway bars front and rear
Wilwood Brakes
315/30/18 tires all around
Borgenson power steering box
Ricks Vaporworx gas tank
De Witts LS radiator
any questions please ask on here or email me
mike@kingind.com
now
Wilwood Brakes
mike@kingind.com
The flares come from corvette Pacifica. I'm not sure who actually makes them. Autocross takes a good car for sure but the driver makes the biggest difference. I feel that auto crossing is 80% driver.
Hi K7,
I'm working on a restomod '67 too and wonder where you got the roll cage and how you like?
Second question is are you running manual (no power booster) Wilwood brakes and if so are they 13" or 14" rotors and what size bore on the MC and how heavy is the pedal when it comes to effort to stop to car?
The cage is from Autopower. The brakes are wildwood 12.8 front and rear. I run a 7/8 master cylinder. They are harder then Power but give a good feel when I'm autocrossing. I may take and get a tune for the Engine since it still has factory tune. Most of the time its plenty of power since the car is light.
I know the ride tech kit uses Fbody spindles...Im considering going that route eventually, just the STG 2 set up. You're the first person I've seen running a manual brake set up with the ride tech spindles...all of the camaro brake kits I've seen seem to have very small front piston area due to the higher pedal ratio in the camaro vs. the vette.
Thanks very much!
