Having problems with clutch releasing
During operational check of everything on my 65 project car I ran into a problem with the clutch not working properly.
I checked the shifter adjustment today and its spot on correct. I re-adjusted the clutch linkage and while the pedal doesn’t feel like I think it should I do feel its close enough that it should work.
Engine Running - Transmission will not go into any gear with engine running. Reverse grinds and cannot move shifter into 1-4 position (no grinding just won’t move)
Engine not Running - Can shift into gears 1-4 and R
I can put transmission in 1st gear, press in the clutch, start engine and with a little RPM I can ever so slightly feel the car wanting to move forward. So this tells me I am not getting full release of the clutch with the pedal.
Installed Parts;
327/300HP, Bell Housing
327/300HP, Flywheel
LUK 04-021 10 ½” Clutch Kit
396/427 19 ¼” Clutch Push Rod
327/300HP, Clutch Cross Shaft (Z-Bar)
386/427 9” Clutch Fork Rod
1965 Clutch Fork
Attached are some pictures, does anyone see anything out of the ordinary? The only questionable non 427 part is the 327/300HP, Clutch Cross Shaft (Z-Bar).
Any Ideas?
Dennis
Installed Parts;
327/300HP, Flywheel
1965 Clutch Fork
Any Ideas?
Dennis
Did you put in a new Pilot Bushing?....
:::EDIT:::
Open up the doc...on JohnZ....Post 4
https://www.corvetteforum.com/forums...-question.html
Post 2 for length descriptions and 5 for some pictures....
https://www.corvetteforum.com/forums...d-bb-zbar.html
:::EDIT:::
T/O bearing
Did you change out the T/O bearing? If so, did you get the correct one? Chevy made two of them, one for passenger cars and one for the Corvette. I installed the wrong one in my 68 and could only get it to shift by adjusting the clutch linkage at its limits. It would still grind when it got hot. I ended up pulling the tranny and replaced the bearing, all is good now. Jerry
Received 1,843 Likes
Adjust the clutch pushrod to make it longer. You have plenty of adjustment room there. That should make it release okay.
When you get the feel right, just make sure you have free play at the top of the pedal stroke. Some say 1 1/2". I like about 3/4".
As JohnZ stated “There is only a very slight difference in the angular relationship between the upper and lower levers on the BB and SB cross-shafts” 135 deg (small block) VS. 155 deg (big block) arm separation so I just can’t see this being the problem.
Jack – I did install a new pilot bushing
Jerry – The T/O bearing is also new and came with the LUK clutch kit. I have been doing this a lot of years and never heard of a T/O bearing being unique to a Corvette??? I have heard of short and long T/O bearings but that would not apply here.
Mike – I adjusted the clutch push rod all the way to it limits (end of threads) and while the pedal does feel better it had no effect on the problem at hand.
I was just out in the garage playing with this and am pretty confident that the clutch is not fully releasing. It’s not your typical stuck clutch problem where you put it in gear and car moved forward while cranking with the clutch in.
Rad Azz for sure. Not sure what’s left to do at this point other than pull the transmission and see what’s going on with the clutch setup. Pulling a transmission on jack stands has got to be the most miserable job to do on a C2 Corvette.
Any Hail Mary’s out there?
Received 1,857 Likes
Sorry, it does apply here. Corvettes (which use "bent-finger" diaphragm clutches) use a "short" 1-1/4"-long throwout bearing, but passenger cars and trucks (which use "flat-finger" diaphragm clutches) use a "long" 1-7/8" throwout bearing. If you use a "long" throwout bearing in a Corvette, it can have the same symptoms you describe.
You haven't mentioned your free play. What is it? If you have "some" free play and the clutch won't release you may have other problems.
My suggestion was simply going by the adjustment in your picture.
Measure all your clutch rods...upper and lower to make sure they are matching what is called for your your car/application...according to JohnZ's post..
"'63-'65 used used the "short" (18") pedal pushrod and the "long" (10-9/16") fork pushrod. '66-'67 used the "long" pedal pushrod (19-1/4") and the "short" (8-9/16") fork pushrod.
If you mixed up some lengths of rods it will cause some issues/problems
This is condfusing. It feels better but it had no effect on the problem? Is "feels better" the same as functionally "works better"?
1965-1966E BIG-BLOCK:
3872962 Cross-shaft - 155 deg arm separation, 4.65” and 4.0” hole centers
3872961 Pedal Pushrod – 19-1/4” long
3872960 Fork Pushrod – 8-9/16” long
3872963 Pedal Bracket
Do you know what ball stud you have installed in the bell housing? With the clutch engaged (pedal at rest) is the fork reasonably close to the front of the opening in the bell housing?
Although most don't have a problem with OEM replacement clutches, Lars demonstrates what some clutch sets do when out of spec:
https://www.corvetteforum.com/forums...vel-range.html
With the pedal at rest the clutch fork is pretty much at the most forward edge of the clutch fork opening. I would have to measure to be sure of the actual position.
Check this...
Verified
Pedal Clutch Pushrod – 19-1/4” long
As for the throw out bearing being installed wrong I'm 99% sure this is not the case as I'm very aware that this can be installed wrong.
Who know for sure but at this point the transmission has to come back out to verify all this.
Just trying to keep you from pulling the trans...
Is it possible you have your Zbar in wrong/backwards...flipped 180*...
