'62 300HP hiccups, misfires then backfires...
Old 09-16-2015, 07:14 PM
Luboxx77
Cruising
Luboxx77's Avatar
Default '62 300HP hiccups, misfires then backfires...
Starts up on whim, idles perfectly at 800-1000 rpm. Very responsive off the block, runs great UNTIL....20 minutes into the ride, engine begins with a light hiccup, then a more pronounced misfire and immediately a nasty back fire and car turns off. Car won't start and when I insist it backfires. I let car rest for 15 minutes. Turns on a whim. Runs great - repeat problem. Temp gauge steady btwn 170 -200. Conditions: 90 degrees, relative humidity 80%. Where do I troubleshoot considering the symptoms described:
- Timing
- Thermostat
- Fuel pump
- Radiator & Fan (both look great, holding anti freeze as directed)
REPLACED: plugs, plug wires, coil (installed MSD Blaster-II coil #8202), distributor, dist. cap, ignition switch.
INSTALLED: pertronix elec. ignition, Edelbrock carb w/elec. choke (replacing AFB carb), spacer btwn carb and manifold, fuel tank filter sock, checked fuel lines.
Engine had a Melling CL-MTC-1 camshaft/lifter kit installed in '92 rebuild by Blairs High Performance in Glendora, CA. Engine has excellent compression.
** Whoever solves the "riddle" receives a $75 Target gift card**
God Bless!
Old 09-16-2015, 07:16 PM
MikeM
MikeM's Avatar
Received 1,843 Likes on 1,398 Posts
Red wire at the bulkhead connector. WAG but it may be worth it for the prize.
Luboxx77 (10-09-2015)
Old 09-16-2015, 07:27 PM
GTOguy
GTOguy's Avatar
Received 3,443 Likes on 2,113 Posts
I'm betting that pulling out the 'upgraded' Petronix stuff and re-installing the original GM points -type distributor will solve your problems. At your engine temps, vapor lock would be fairly unlikely, but still a possibility.
Old 09-16-2015, 07:28 PM
Luboxx77
Cruising
Luboxx77's Avatar
Thanks. Will take replies for a week or so and then troubleshoot. Happy to award giftcard if problem is solved :-)
Old 09-16-2015, 07:43 PM
Donald #31176
Donald #31176's Avatar
Is the intake manifold heat cross over blocked off?
Is the heat riser on the exhaust manifold working or wired open?
New Pertronix ignitors require 12 volts to run. Perhaps the coil is mismatched and cannot run well on 12 volts.
PS 62s do not have a bulkhead connector.
Old 09-16-2015, 09:18 PM
jim lockwood
jim lockwood's Avatar
Received 6,507 Likes on 2,996 Posts
C2 of Year Finalist (track prepared) 2019
My bet is the MSD Blaster coil is failing.
Jim
Old 09-17-2015, 03:54 AM
Randy G.
Randy G.'s Avatar
Gas tank vent/cap.
Old 09-17-2015, 05:45 AM
tbarb
tbarb's Avatar
Jim
I am with Jim, change the coil.
PS, can we split the Target gift card.. :-)
Old 09-17-2015, 09:22 AM
DansYellow66
Support Corvetteforum!
DansYellow66's Avatar
Received 2,615 Likes on 1,947 Posts
I'm with Jim and tbarb. The coil. But they said it first.
Old 09-17-2015, 10:02 AM
Luboxx77
Cruising
Luboxx77's Avatar
Jim, Dan, Tbarb, coil has been changed on several occasions (OEM's). I now have a collection. Sorry.
Old 09-17-2015, 10:26 AM
After38Years
After38Years's Avatar
Does the failure occur after 20 minutes on the same road types - hills, flat, etc, and does your car have a fuel filter?
Old 09-17-2015, 10:57 AM
Luboxx77
Cruising
Luboxx77's Avatar
South Florida is as flat as they come. I run the car hard. I will take an occasional sharp curve or turn.
Old 09-17-2015, 11:20 AM
MikeM
MikeM's Avatar
Originally Posted by Luboxx77
REPLACED[/U]: plugs, plug wires, coil (installed MSD Blaster-II coil #8202), distributor, dist. cap, ignition switch.
God Bless!
Were these changes done before, during or after or all of the above when you had problems?
In the meantime, hook up a 12 volt test light to the minus side of the coil and put it in the cockpit where you can see it. Ground the light and take off for a ride and see what happens.
If you happen to have an electronic tach, you can just watch it when it starts acting up and report on what it does. Same deal.
Old 09-17-2015, 11:26 AM
Luboxx77
Cruising
Luboxx77's Avatar
The problem has been festering for 18 months. Car performs much better in colder, drier winter weather in south florida (btwn 70-80 degrees). This entire summer car won't run more than 20 minutes in stop and go traffic and 50 minutes on the highway. Most of these changes were done 18 months ago when the problem began, except the coil which has been changed 3 times in the last year.
Old 09-17-2015, 11:54 AM
tuxnharley
tuxnharley's Avatar
Received 1,937 Likes on 1,183 Posts
Here's my SWAG - debris/crap in the gas tank that accumulates on the pick up inlet/"sock" after driving for a while, and then settles back away when it sits.
Have you looked in the tank?
Old 09-17-2015, 02:24 PM
toddalin
toddalin's Avatar
Received 1,152 Likes on 484 Posts
Did you do anything about the ballast resistor (retain, remove and jump, replace, etc.)?
If it is still in place, it can get hot and cause an intermittent "open" creating the problems you describe.
Old 09-17-2015, 03:13 PM
Luboxx77
Cruising
Luboxx77's Avatar
Ballast resistor was "bypassed" when the pertronix was installed.
As for debris in gas tank, could be, but would it make the car sound flooded and generate backfire before cutting off?
To '62 300HP hiccups, misfires then backfires...
Old 09-17-2015, 03:20 PM
Luboxx77
Cruising
Luboxx77's Avatar
Yes, placed a FI intake manifold gasket so the heat cross over is blocked off.
I believe the heat riser on the exhaust manifold is wired open.
Old 09-17-2015, 05:00 PM
MikeM
MikeM's Avatar
This thread is reminding me of the old TV show, "Green Acres".
Or "Pin the tail on the donkey".
I see FTF cleverly deleted his "Mr Haney" post here. Why?
Old 09-17-2015, 08:17 PM
MikeM
MikeM's Avatar
I don't understand why people that want to help don't ask for a better description of the problem before they start giving advice on what's wrong? Maybe it's just me?
Quick Reply: '62 300HP hiccups, misfires then backfires...
