How to install midyear hardtop
My 66 convertible is my first one with a hardtop. All the other midyears have been coupes or had just the soft top. My question is how to best install the two bolts going down through the rear deck that have nuts underneath. The soft top seems to prevent me from getting my hand under there to put the nut on. My solution has been to set the top on the car, install and tighten the side bolts and then lift the attached top up slightly. This is a two person operation so one holds the top up while the other installs the nuts. Is there a better or easier way? I never had this issue with solid axle hardtops because the back bolts are easily put in from the top.
POSSE ZR-1 Driver
It is indeed a tight fit back there with the soft top folded up.
I took a different approach.... When using the hard top, I remove the soft top completely. I marked the position of the brackets so when reinstalled, it fits correctly.
With the soft top removed, there is a lot of space for luggage, folding chairs, etc...
My '64 ran with its removable hardtop for years with only the side hold down bolts in place. The rear deck hold down bolts were not used. Never had a problem running that way.
Heck of a lot easier when removing the hardtop to go topless. Since acquiring a soft soft top the hardtop is stored hanging from the ceiling in the garage.
John
John
Received 1,843 Likes
Bill,
I just did it for the first time this week on my 67. Used your method, but did it myself after my wife helped me lift it in place. Not an easy thing to do.
Bill.
When I used those rear deck bolts I did it just as you describe also. That is the easiest way with the soft top installed but I do now just leave them out when I put on my hardtop. It is secure without them.
Don
Don
Mr D. (09-20-2015)
But I did use the clear plastic deck protectors. Was worried that, without the rear bolts, the rubber might wiggle around more and chafe the paint. Maybe not a real issue, but I felt better with the protectors (which I made from 40 mil rear window plastic).
That's how I did it when I ran a hardtop on my '65.
Don
