Routing Spark plug wires on a C2 327
St. Jude Donor '09 & '11
I'm not mechanically impaired so I just can't believe what I see on my 65 327 is correct. The two front spark plug wires on both sides of the engine are routed between the block and the motor mount!! Surely this is not correct? I can't find any info on correct routing of the plug wires. Anyone have pictures or a reference??
Received 6,928 Likes
2015 C2 of Year Finalist
That's correct. Buy your self the AIM and the GM service manual
Received 1,856 Likes
pull the boots down on the dist end of wire, wrap the ends in tape, run through motor mount. Once through, put some vasoline on wire end, put the boot back on and remove tape and clean any vasoline residue, a little dielectric grease and your good to go.
Received 1,843 Likes
Minor point. Aren't the wires supposed to cross each other in the loom just before the spark plugs instead of running parallel?
Now you're getting picky..............
Most folks probably don't have any idea, but if you run the "R" sparkplugs it probably won't matter.
The rubber wire holders actually have the spark plug wire numbers on them for you to follow.
Larry
I think the wires are crossed in that loom to lessen the chance of breaking the electrical conductor in the plug wire with such a sharp turn.
JUst doing a memory check.
The wires cross each other on the rear cylinders but are parallel on the front cylinders just as JohnZ has shown.
In the picture shown above by Frank is what a non radio car will have. To see what was added for a radio car that will be in the U69 radio section in the AIM.
CrossedUp (10-02-2015)
That illustration doesn't show the two wire clip on the front two cylinders which is what I was talking about. Item 14 in the drawing. Seems like many/most/all undisturbed engines from the factory, the front two wires were crossed in that clip. Maybe not?
Again as shown JohnZ's pictures
