New temperature sensor same problem.
Old Oct 10, 2015 | 03:55 PM
cblankin's Avatar
cblankin
Default New temperature sensor same problem.
Replaced the temperature sensor with a TU5 sensor and the same results. Temperature gauge needle peeks out at about 135 degrees. When I ground out the dark green wire needle goes full scale deflection toward hot. I traced the dark green wire (has a black protective sleeve over it) and it seems to go into a bundle of wires. I traced those wires to one of 2 bulk head plugins They are somewhat under the power brake booster. Would disconnecting the one that is farther from the drivers fender and apply some die-electric grease do any good. If so how do you disconnect the bulkhead plugin. Non-Contact Infrared Thermometer on the thermostat housing I get a reading of 190 degrees.
Old Oct 10, 2015 | 04:03 PM
JohnZ's Avatar
JohnZ
Originally Posted by cblankin
Replaced the temperature sensor with a TU5 sensor and the same results. Temperature gauge needle peeks out at about 135 degrees. When I ground out the dark green wire needle goes full scale deflection. I traced the dark green wire (has a black protective sleeve over it) and it seems to go into a bundle of wires. I traced those wires to one of 2 bulk head plugins They are somewhat under the power brake booster. Would disconnecting the one that is farther from the drivers fender and apply some die-electric grease do any good. If so how do you disconnect the bulkhead plugin. Non-Contact Infrared Thermometer on the thermostat housing I get a reading of 190 degrees.
It's a good idea on any midyear to disconnect those two 8-way connectors, clean the terminals of any corrosion, and apply dielectric grease to protect from further corrosion. You squeeze the black plastic tangs vertically to disengage the locking feature - be VERY GENTLE with the lock tangs - they can break easily.
Old Oct 10, 2015 | 04:39 PM
65GGvert's Avatar
65GGvert
I'm guessing you didn't believe me yesterday.
https://www.corvetteforum.com/forums...uge-error.html
Old Oct 11, 2015 | 12:10 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
You have proven the gauge is working but is it working correctly? You can figure this out pretty easy. If you have a potentiometer use it as your source ohms and test the gauge.
If you don't have one... an old cheat trick is to use a flasher. A turn signal flasher has around 50-55 ohms resistance so if you have one laying around whip out your ohms meter and take a reading to see. Then insert this as your sender and see where the temperature gauge goes. Once you know the input you can match it up to the chart below and see if the gauge is working properly. If you want to raise the resistance just put another flasher in a series.... and you'll be around 100-110.
50-55 ohms on a 65 gauge should put it past 240. On a 66-67 gauge it should take it to the 250 mark. If you double the flashers up though you'd be around 100-110 which would be somewhere between 180 and the second mark on the 65 gauge face and right at the first mark on a 66.
If you find the gauge to be reading correctly then punt.. get the adjustable resistor and you can match any gauge to any sender for 1965-1967. (sorry 63-4 guys, we don't have a solution for you yet).
https://willcoxcorvette.com/corvette...resistor-65-67
65-67
Old Oct 11, 2015 | 01:05 PM
irwiny's Avatar
irwiny
If your getting a low reading and when you grounding the sensor wire shows a full deflection on the gauge, you have extra resistance somewhere from the ground of the sensor to the gauge. Adding resistance with variable resistor (pot) will only lower the gauge reading even more. Most people have the problem of reading high when the car is not hot. Only then you review how to add resistance to the circuit.
Warm up your car test with IR temp gun - do some research regarding what it the correct resistance (sensor output to ground) and get/borrow a Ohm test meter. Most likely something is not grounding correctly with the sensor. I read having too much Teflon on the treads of the sensor could be something to review. Use only enough Teflon to seal the top of the senor's mounting threads and not all of the threads.
Irwin
Old Oct 11, 2015 | 05:15 PM
cblankin's Avatar
cblankin
Default Can't seem to fix the problem
Made sure the threads in the intake where the coolant temperature sensor screws in were clear and did not use any Teflon tape or thread sealant and still temperature will only go to about 135 degrees on the gauge My Non-Contact Infrared Thermometer pointed at the thermostat housing I get a reading of 185 degrees. The thermostat is fully opened. When I ground out the wire going to the sensor the gauge needle deflects full scale to the right. After the engine cooled I opened the coolant recovery tank and about 8-10 oz puked out. How do I replace what I lost?
Old Oct 11, 2015 | 06:53 PM
irwiny's Avatar
irwiny
Measure the resistance of the sensor and ground after warming up the car. That's the first step to determine if it's the Guage or sensor issue.
Old Oct 11, 2015 | 07:03 PM
Powershift's Avatar
Powershift
This is what we told you to do a few days ago when you asked:
https://www.corvetteforum.com/forums...ding-unit.html Post #4.
Here is a thread from someone with a similar problem a few weeks ago, and our forum recommendations. From the archives: https://www.corvetteforum.com/forums...r-fitment.html
Larry
Old Oct 12, 2015 | 10:16 PM
Craftsman51's Avatar
Craftsman51
good thread and information.
To New temperature sensor same problem.
