Power Steering Pivot Bolt
Inquiring to find out if anyone would know the length and size of the power steering pivot bolt for a 66 BB. I am unable to get the power steering pump to stay tight and believe the threads on the bolt are stripped.
Received 6,940 Likes
2015 C2 of Year Finalist
Well take your striped bolt and go to your local hard ware store and get a new bolt
If I remember correctly, big block power steering pumps mount like small blocks with the pivot bolt secured by a nut, lock washer and flat washer on the back of the lower bracket. Take a look at your AIM, it's UPC N40, sheet A7 in the '67 AIM.
Are you sure the bolt is stripped? The pivot bolt is secured with a loose nut (not welded to bracket), lock washer and flat washer. If you don't hold the nut with a wrench, you probably aren't torquing it properly.
