64 fuel sending unit wiring question
I'm doing my rear tail lights and reconnecting the rear wiring harness. It is the original wiring and sending unit, although I removed the sending unit and replaced the seals. I don't remember all the details, but I notice one of the sending unit terminals is a different diameter than the other. Of course, the wire for the larger one seems to "remember" going to the smaller one (and vice versa).
Is there a good chance I mistakenly swapped the terminals as I was changing the washer/seal?
I think I know the answer, but before I go taking it apart... I though I would ask.
This is perfect info. and all i will need to answer my question.
I'm trying to figure out if I mistakenly swapped the terminal for the Brown wire to the position of the Black/Pink, and vice versa. Once I get home again I can compare to these pics and should be able to figure it out.
Thanks,
Thanks,
I did not make the mistake I suspected. The black/pink wire is just very tight running from the clip over the reverse light to the terminal.
