Dash Pad Removal
Remove trim at base of windshield and if i remember you need to take off the side moldings going up the sides also..
Remove glove box
Remove Radio
Drill out the 'steel' rivets in door jam
Using a flat tip screwdriver and insert in clips on and around dash...the ones by the radio are a b!tch to remove...
By looking at the bottom of dash..Take off the 2 nuts on bottom of dash where glove box was...
Reverse process...
Have fun....
Remove glove box
Remove Radio
Reverse process...
Have fun....
Your right...got carried away on disassembly....
You'll want to edumicate yourself on those pesky butterfly clips....see attachment.
Many replace them with short screws. I put 'em back in but then I'm 'hard core'.... The clips down the side of the center waterfall are tough to get to but it can be done
