C2 aluminum aftermarket wheels stud length
When my C2 with steel wheels, the lug nut had the threads come through just about flush. Now that I have changed over to thicker aluminum aftermarket wheels (which use a tapered thread lug nut), I question whether the original wheel studs are long enough?
Thanks!
Thanks!
The aluminum wheels had a nut with a shank that fits into the wheel? if so you will be aok...You need 7/16''-1/2'' of the stud threads IN the lug nut....anymore means nothing...
The type of lug nut you're describing "tapered thread" is not clear. Do you mean a tapered base lug nut, like used on steel wheels? If so, as long as a thread or two of the stud protrudes past the end of the nut you're OK. If the studs don't protrude the full length of the nut, the studs are too short.
A picture would help.
I'm sure an engineer type will chime in but that statement is not entirely true...
if the stud is 7/16'' in dia. any MORE than 7/16'' threaded in to a lug nut is overkill...if the lug nut has 3/4'' of threads the stud does NOT have to poke thru...7/16'' is mechanically as strong as it can get.
My aftermarket aluminum wheels use a tapered thread lug nut, (like a regular steel wheel would). The threads, without the nut, only protrude about 3/10 of an inch (6 turns of the lug nut on 7/16"X 20 threads - because the aluminum wheels are thicker than the steel wheels. I think I need longer wheel studs.
My aftermarket aluminum wheels use a tapered thread lug nut, (like a regular steel wheel would). The threads, without the nut, only protrude about 3/10 of an inch (6 turns of the luh nut on 7/16"X 20 threads - because the aluminum wheels are thicker than the steel wheels. I think I need longer wheel studs.
Received 1,843 Likes
Ford standard for thread engagement. Thread engagement equal to the diameter of the stud plus a couple of threads.
GM standard may/may not be quite as robust.
St. Jude Donor '07
Bill
Like these, right? They're the ones labeled "Hex Nut-E.T. Extended Thread" and they're the style I have on my 63 with Billet Specialties aluminum wheels.
jkmhb (04-28-2016)
My rims - Torque Thrust M's - use the Hex Nut - Conical Seat
Since the lug nuts are solid on the end, I cannot see if the thread go through like you would on a factory lug nut. But I am only getting 6 turns, which is too short.
1 3/4" length studs seem to be readily available. I'm going to see if one of these are long enough before I buy a full set of replacements.
Thanks Mike! These did the trick. A lot easier than changing the wheel studs! I agree the rim manufacturer should have suggested these, but they did not.
Received 1,534 Likes
Be careful not to have the studs too long and bottom out in the enclosed lug nut. With the wheel bolted in place with 4 nuts and snug again the hub, You need to measure the stud projection on the last stud. Measure the depth of the hole in the enclosed lug nut for your wheels. The stud projection should be approximately 1/8" less than the lug nut depth, but have a minimum of 1/2" engagement to get 10 threads.
Because your new lug nuts are of the tapered type like the OEM nuts for steel wheels, you can just put an OEM nut on to verify the minimum engagement (full nut plus 1 thread projecting).
If you had a shank on the new lug nuts, you must put them in the wheel to verify you are not projecting past the back of the wheel. The shank should be about 1/8" less in length than the depth of the wheel with any required washers in place. Not rocket science
Just a personal preference, but when running the Mag type or ET extended thread type nuts, I like to have more thread engagement to get into the thicker portion of the nut. I don't believe the extended shank which is only about 1/16" thick has the same strength as a regular nut with about 1/8" thickness. Call me crazy, but loosing a wheel is not good. I ran the open end type Mag nuts on my 3500# car so I could see the ugly studs. When you launch on the two rear wheels, you need both of them until the front end comes down.
