Bird Cage removal
Bird Cage removal
Good afternoon gentlemen,
In the process of tearing my car apart I have discovered some damage to the driver side bird cage along the rocker as well the the door pilar. I'd like to remove the cage and make proper repairs.
Can anyone give some insight into the process or share some experiences with birdcage removal? I have had little luck with researching this topic.
Thanks In advance,
JJ
Thanks In advance,
JJ
Just did a search on the Forum....
Lots of reading 'threads' for you to look at from those that have worked on the birdcage...some with pictures and links to purchase parts...
Good luck...
https://www.corvetteforum.com/forums...rchid=54091546
Good luck...
That's a MAJOR undertaking to get to both of the areas you describe. Basically, you have to disassemble the entire body and interior to get to them. That includes debonding the fiber glass from the metal structure.
Best Wishes!
Best Wishes!
I did a quick write up on doing rocker channels this winter. As stated above, complete tear down to the bare cage is very intensive and probably avoidable if damage is not too severe. The hardest part is finding all the spot welds to cut out. Caldonia re-pops are pretty good.
Best of luck.
Best of luck.
I have a rocker channel on order from paragon and that section of fiberglass will be removed and replaced, my largest concern now is the fwd door pillar and if I can possibly service that without cage removal.
The body is already down to a shell and will be lifted off the frame and soda blasted soon. I just need to establish how much further I need to go to properly fix the cage.
Could you send a link to your article?
Thank you,
JJ
Thank you,
JJ
Best of luck.
Best of luck.
https://www.corvetteforum.com/forums...-roadster.html
Hopefully the above link works. If not, check under my posts on my profile.
Best of luck.
Best of luck.
Thank you.
I would say at the very least you would benefit, from removing the side fender. I have replaced lower a pillars on C3's without disturbing fender but they are different. The midyears are a more complex construction. If the rocker channel was removed, you may be able to cut the bottom few inches off the pillar and remove / install from the bottom. Then fit and weld in place before re installing the channel. Really depends on how bad and high up the rust goes up your pillar. Have any pictures?
Here's another picture of the C2 birdcage, from a slightly different angle I snagged off the Forum for reference...
Good luck... GUSTO
Derek, thanks, and you're right. I had to look at it twice to see it... DUH!
Good luck... GUSTO
