Frame Rail Fuel Line
I'm looking at the fuel line from rear to front along and in the frame and I'm thinking the body probably has to come off to replace it. I have no plans to lift the body as the frame is in pretty good shape.
Am I right in thinking it has to come off and is there another alternative like maybe aramid backed hose? I'm all ears
Received 6,943 Likes
2015 C2 of Year Finalist
its much easier to replace with the body off. I have read on here of people removing the tail lights and snaking it thought there
Received 1,857 Likes
'63-'67 all used the same design, with the rear half of the fuel line buried inside the rear frame side rail; they didn't fix it until 1968, when they re-routed the rear half outside of the frame rail.
1. Raise the body about a foot and replace the line as one piece (do the brake line on the other side at the same time).
----OR----
2. Cut the new line in half and install the halves individually (add a union where the line exits the grommeted hole in the front of the kickup and heads downhill).
----OR----
1 correct one piece fuel line
2 while body is off replace the brake lines too
3 the rear body mounts tend to rust out. The stepped shape rubber washer traps water and the hole opens up and the rubber stepped washer starts to fall thru the body mount.
4 replace the transmission heat shield that attaches to the tranny tunnel
5 all new body mount hardware
I had a shop remove the body on my 66 and although expensive I felt good about new fuel and brake lines. My old fuel line had been repaired twice before
The archives have all the details.........should be under his name.
If I were to use a compression fitting, I would buy a Parker of Swagelok "industrial quality" fitting. We used these all the time in the chemical plants for some fairly hazardous materials. They go on right and NEVER leak.................even at 1000's of psig pressure. And our C2 gas line operates at about 1 psig MAX................probably under a slight vacuum most of the time.
Larry
Ok guys, I pretty much figured it would be something like what you have suggested. I'll buy the new line and get her on the lift and make a decision based on what makes most sense considering time and what's practical. I may do the silver solder slip fit method. Thank you, I'll make it happen
Here is the thread I referenced. This and many others like it in the archives if you search under "gas line replacement" or something similar in the C1-C2 Forum Section..
https://www.corvetteforum.com/forums...placement.html
Mike Coletta is still around and a C2 Forum member, if you need to contact him for additional advice or clarifications.
FWIW, the 1966 brake lines can be replaced with the body still on the frame. I did it along with many others..............and the finished job looked and performed very well.
Larry
I appreciate it. The existing fuel line is just pitted a bit too much for comfort and that's just in the areas I can put my eyes on. I'll get it done and thanks for the help guys.
There are some other benefits to taking the body off
Then, while you are there:
1. replace u-joints
2. rebuild brakes
3. replace gas tank (much easier with body off)
4. that rear spring looks tired - probably swap with composite
5. replace carpet
6. LED tail lights
7. New license plate bezel
8. Side exhaust
9. New Steering wheel
oh. sorry. The disease kicked in. Carry on.
Good idea.
1. replace u-joints
2. rebuild brakes
5. replace carpet
6. LED tail lights
8. Side exhaust
1. replace u-joints
2. rebuild brakes
5. replace carpet
6. LED tail lights
8. Side exhaust
Larry
Replacing a fuel line can turn into a body off restoration so fast it'll make your head swim!
Received 5,009 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
It's been 7 1/2 years, I'm guessing the issue has been resolved by now.
It looks to me like that there is some remnants of factory black paint on the portion of the frame shown in your picture. To me that is a good sign that you don't have any significant rust issues with your frame.
