327 rear main seal
327 rear main seal
I am seeking recomendations for a rear main seal for my 327/300 rebuild. Felpro has silicone and the fluroelastomer. Comments please.
Brgds,
Rene
Brgds,
Rene
Received 1,843 Likes
The OEM style works fine for years. Don't know about this new fangled stuff.
Whatever FelPro recommends would be fine with me.
Received 2,127 Likes
That's what I put in mine 2 yrs ago. Offset it about 1/4 inch, dab silicone on the main edges, torque it and go. Dennis
What I was trying to say was the original main seal that Flint Engine installed in 1965 is still in place and not leaking a drop.
I also have a rear seal leak on my 327/350hp, some detail pics of your repair would be great, I have never changed a seal while still in the car, how much of a pain is it whiteout a lift. Ian
So far it was easy enough to jack up the car, disconnect the idler arm and remove the pan. Just remove the oil pump and you can get to the rear main. Now i am guessing you can rotate the top half of the seal out of the main and rotate a new one in?
Also I didn't have to touch the idler arm to drop the pan. Much easier on a lift.
The 2912 can handle more RPM and heat. These old Vetts spin a lot of RPM so this seal works better in them.
The upper seal won't jump out you will have to encourage it. A brass drift may be necessary to tap lightly and get it started then you can crab it with needle nose pliers and pull it out. The new one will need to be lubed well prior to install to help it slip in.
If you loosen the last three main caps the crank will sag a little and give you a touch more room for the seal install.
Make sure both half's of the new seal get fresh oil prior to install so they don't run dry on initial start up.
A small dab of silicone on the end pieces helps seal them together on install. Small dab is important. Extra will just make a mess.
Be sure to re torque those main caps prior to pan install.
I guess you have driven your car enough to know it needs one. When I purchased my car, it had been driven very little in 8 years, only 300 miles. When I started driving the rear seal leaked. Now as I put miles on the car it stopped leaking. Just needed some driving time for seal to seat.
Guess I'll just sit in the rocking chair on the porch and reminisce about the good old days - dammit
