SB Engine Casting #s
The engine runs OK, strong in high RPMs, but has some drivability issues, mostly related to tune. It doesn't have a vacuum advance on the dual point distributor. Compression is great in 7 cylinders, with one cylinder down slightly, but still in spec. It holds good oil pressure. It has a Holly 2818 carb on a Weiand aluminum manifold. It has an M20 transmission and 4:11 rear.
To start with I'm trying to figure out what to do with the engine. It is a non numbers matching block with no serial number. The casting number is 3959512. What are the differences between the block I have and the 3782870 casting the car should have? Is it worth working with the block I have or should I shop for an engine with different casting number?
I would like to keep the engine period correct.
TIA, Gene
Dennis
TIA, Gene
Bluestripe is giving you good advice. I would add that the carburetor is likely contributing to driveability issues. Replace it with a new Quick Fuel 650 carb and you'll think you have a new car. Trust me on this. If your intake is single plane, then the 2818 won't like it as much as the QF carb will. I wouldn't change the intake. I'd do the distributor and carb first.
Instead of changing diff gears, I'd go with a Legend 5 speed. Do you know what your cam is? How high is high RPMs? Elaborate on your driveability issues.
Here is the best distributor for your engine:
http://www.summitracing.com/parts/msd-8572
The cam is not a solid lifter, but lopes a lot at idle.
Changing out the distributor is in my plan. I think adding vacuum advance will help the drivability a lot. I would like to change out the 4:11 gearing too.
Gene
TIA, Gene
1. The best improvement for drivability in your case would be adding vacuum advance and dialing in your distributor.
2. With an M20 and 4.11 gearing, there should be no lag problem, but apparently there is; if I make the assumption that you have the 30-30 Duntov cam (or hydraulic equivalent), sluggish starts are annoying, but with your low total gearing (2.52 x 4.11 = 10.35), you have the right amount of gearing and shouldn't have launch difficulty unless there are other problems.
Here are a few ideas: Make sure your 2818 carb is correctly built and it doesn't have some Bubba arrangement to open the secondaries prematurely. Secondly, get a good 2-plane manifold like the stock L76 aluminum high rise, or the later LT1 manifold which will improve low end torque over a single plane manifold.
3. Figure out how you want the car to perform and pick a better cam. I would guess that you have way too much duration for what you want.
4. Your engine block is fine - it is period correct, but even if it were a 2870 block, it's still not the original motor.
5. The MSD distributor, although it will work well, is too tall to use the stock ignition shielding. You may want to consider one which has the original style socket style ignition cap.
Good luck with your project!
That's my plan, to start with the distributor. Now I need to figure out what I want to replace it with. I know that's a hot topic on the forum. I don't want to start a problem topic.
A new holley 600 is a few dollars over $300 or send the 2818 out for a nice restore to Eric for probably about the same.
