Solenoid to coil wire on '56
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
I think a wire on the solenoid post pointed to in the picture goes to the coil + terminal.
Correct?
Correct?
Yep, as long as it does not have a S on it, It should be hot ONLY when cranking to let the coil produce 12v at starting, goes to the same side of the coil with the braided cover, after start the one at starter goes dead and the braided wire takes over at lower voltage.
Did I make this clear?
55 had no accessories so the solenoid I posted above had no acc. Post . In 56 GM carried the same design over but later they added a post for accessories .So like I said 56 used a fuse type part as a accessory post for a 56 solenoid not having the extra post. But if you had accessories like Power windows or power top. The (fuse) As seen below.
Thanks!
