Uneven gap shroud to radiator?
I noticed a that the spacing/gap between fan shroud and radiator is uneven. If you look at the image, the drivers side i flush and passenger side has a gap.
At first I thought my radiator is off center, but the gap to the right of the radiator is pretty even. So I'm not thinking the radiator bottom mounts are okay.
66 Coupe NOM - 327 L79 (65) w/AC.
Car runs pretty cool (180-200 normally) with 180 thermostat currently.
What should be the spacing between the shroud and radiator and your suggestions in correcting the alignment ? Maybe put a spacer on the drivers side shroud mount or am I missing some hardware that squeezes the drivers side shroud closer the the radiator?
Thanks...
Irwin
Thanks...
Irwin
