[C2] BB Radiator with SB Engine, Hoses
St. Jude Donor '05, '09, '15
I installed a Dewitts 66 BB rad with electric fans, also 66 BB rad support, in my 65 SB. I am have trouble finding a lower rad hose. BB hose is too short and SB hose is too long. Anyone using this rad with a SB? What lower hose did you use?
Tom
Tom
Received 6,519 Likes
C2 of Year Finalist (track prepared) 2019
If you go this route, be sure you use a splice tube with barb ends so pressure won't blow the hose off.
Jim
Take a look at Speedway Motors:
They call this "straight aluminum hose connector, 3 inch" and is available in a variety of ODs. It's not what I used (and I can't find a listing for what I used), but it will do what you need.
Jim
Sky65 (05-16-2016)
Tom
I'm using a Dewitt's BBC radiator and the '67 BBC lower hose with a SBC and it fits pretty good. I see that CC lists two different lower BBC hoses. I have the 3882826 "427 ALL" vs "396/L88".
C2 of Year Finalist (performance mods) 2019
I was through this a while ago and this thread might help:
https://www.corvetteforum.com/forums...gine-swap.html
