antenna wire replacement
Received 6,943 Likes
2015 C2 of Year Finalist
This is one of the few times having side exhaust is a plus. If you have under car exhaust you will have to remove the exhaust on the drivers side. Unless you got real long skinny arms. Your also have to peal back the carpet on the wheel hump on the back remove the trim part behind seat, door sill and kick panel Then it's a matter of snaking it around the dash and into the radio.
To add to Nowhere Man's post, if you have a coupe, you'll also need to remove the rear blower assembly. I have lots of pics. of my 65 while doing a body-off restoration. Let me know what you need.
The attached PDF has some photos taken when we recarpeted our '65 and replaced all the wiring.
Hope this helps!
Dave Z
JL66REDCPE (05-25-2016)
