Horn Relay Restoration
This is a re-post that I thought some new owners may want to read
Hi,
After 46 years (2012 ), horns stopped working, relay would click but no Toot or Tweet Tweet
I took apart the horn relay. I found 46 years worth of rust and junk, but all was intact. Filed points and cleaned up case and base.
As you can see from photos, the coil and thin wire from the contact to coil was still intact. Once I cleaned parts and did a little rust prevention, I put back cover, installed back in car and
My two tone horns are working again. I wait on the silver plating, save it for my son when he gets the car.
The pictures are in order of taking apart and working on parts
All cleaned and ready to put back in car
Toot! Toot! Tweet! Tweet! 50 years later........
Hi,
so, this is like a Re- Tweet?
Jackfit (05-27-2016)
Oh, that's easy. But good to me might be different than good to you. I like aged, but clean. So, I cleaned mine with orange pumice hand cleaner. I get a good glop of it in my hands, and then I rub the cap all over the top and sides, in the crooks and cranny's, for about 10 mins,
then wash off with water.
Mine came out super nice and clean, but still with aged patina.
Try it!
ps,
you should have just a paper gasket. Cork and rubber do not compute.
Try it!
ps,
Try it!
ps,
Try it!
ps,
Here's where I am with mine, still not done with it, But sorta satisfied so far.
I used Mother's Aluminum & Mag Wheel Polish, a 6 in. soft cotton buffing wheel on the outer part and 1/2 in. buffing wheels on my Dremel.
A lot of work but haven't burnt thru the cad plating....yet.
