Electric cooling fan current draw, engine idle speed
St. Jude Donor '05, '09, '15
I am in the process of getting my 65 running again after an accident. I had to replace the radiator and fan so I changed from the belt driven fan to a DeWitts BB aluminum rad with dual Spal fans. They work fine and cycle on and off as they should. Problem is when they cycle on the engine speed drops about 200 RPMs. I guess from the increased load on the alternator . Is this normal?
Tom
Tom
Received 1,843 Likes
Weak battery?
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
Tom
Tom
Received 1,581 Likes
St. Jude Donor '20-'21-'22-'23-'24
I upgraded my alternator when I added a SPAL fan. My battery gauge needle swings to the left momentarily but rpms don't drop.
Steve
Steve
St. Jude Donor '07
I ran an extra 12gauge wire from the alternator to parallel the original wire (the original wire is spliced into the new 12gauge with a pigtail wire running to the horn relay to power those things running from the relay terminals) to the starter, just like the original. the fan power & controller were spliced into the new 12gauge, the old wire continues to 'power' the rest of the car.
because part of the circuit no longer runs thru the ammeter, it is not exactly accurate anymore; but, who cares....
other than feeling like I've been 'kicked in the chest', I'm doing fine... thanks for asking...
Bill
Sorry I left some info out. I have a new AAW wiring harness and my old 100A Power Master alt. Charging wire from alt is 6 gauge to battery. Battery cables are 2 gauge Pos and Neg. Fans are powered by an 8 gauge wire from main fuse panel to an aux fuse block next to the fans. 2 30A fuses with 10 gauge wire to separate 40A relays. One for each fan. Fans are grounded to frame. I feel good about the circuit capacity. The engine is a modified 355. Probably 425 hp. Maybe it has to do with the cam grind?
Tom
Tom
Moderator
I have spalls on my old Cherokee (with a circa 1988 chevy 350). their web site will tell you exactly how many amps they draw, mine draw 40amps each on startup.
while you're at it, may also want to check to see if output wire on your alt needs to be upgraded. and make sure you connect them to properly rated relays.
edit-- looks like you already took care of the wiring.
powermaster is a decent alt -- I have their 200amp, but 100amp should be more than enough, assuming you're not running a crazy 'thump'n stereo or other large draw.
FWIW, I had a 110amp alt in my Cherokee w/ 3x spalls, before upgrading to a 200 amp power master, the rpms did dip momentarily (a second or two) when they kicked in. Now I notice nothing.
Dewitts told me the fans draw 26 amps total when running. Did not mention startup amps. I bumped the base timing up a little and it seemed better. I have to "clearance" one if the header tubes. Then I'll get back to it.
Tom
Tom
Steve
Bill
Bill
I upgraded to a 100 amp alternator because I have Vintage Air and a DeWitt's/Spal Combo Fan. I didn't change any of the car's wiring.
I didn't install the combo fan or the A/C but the fan was set up to take power directly from the alternator's power supply post and the A/C was set up to take power from the starter. FTF advised me to switch to the horn relay as a power source for the A/C to resolve a battery gauge aberration so I changed it and all is good.
"Kicked in the chest" by an angry mule is probably more accurate than just "kicked in the chest" <LOL>.
Steve
St. Jude Donor '07
With a 140 amp alternator, you must be running more stuff than just a fan.
Steve
Steve
I am no longer using the Lincoln Mark VIII fan as I managed to burn up a couple of expensive controllers through some dumb things I did, so I'm back to the mechanical flex fan.
BUT I do have the a/c and a condenser pusher fan to run, and I have plenty of amps to spare...
and, you are correct in what you did with your wiring as my ammeter is no longer accurate because the additional wire splits the current flow (only part going through the gauge); but then I don't care how accurate the gauge is..
Bill
