66 speed odometer starts too high
Buying a 66 coupe this week
Is it. Big deal to repair?
Do you know a vender
Thanks in advance
Chuck
Thanks in advance
Chuck
could you clarify your question, what does "starts too high" mean? It reads a higher speed than actual speed? It doesn't move initially and then jumps up?
2016 C2 of the Year Finalist
Are you referring to the Speedometer? The odometer records mileage. Not sure how that could read too high. They usually just stop working which is related to gearing in the speedometer.
The vendor you need would depend on you giving us more specifics on the problem you want to solve.
Speedometer
Sitting still speed indicator stays on 50 mph not 0 mph
I agree that the gears are worn on stuck
Looking for a vendor parts supplier
Long Island Corvette has calabrated head assemblies available as do others. Paragon, Corvette Central and Corvette Specialities and several independent rebuilders have rebuild services as do others. Enter Speedometer Repair in the Search bar for this forum and you'll get much more information.
I agree with desert pilgrim that the seller should fix it and if not knock about $300 off the price so you can have it repaired. More $$ if you have someone else R/R the cluster.
