[C1] 57 Corvette Defective Ignition Switches
Has anyone got a defective ignition switch for a 57 Corvette ? We are on our second aftermarket switch and it seems defective. The first one worked the way it should two times to start the car then it jammed between the off and on positions and wouldn't turn to push the brass peg to release the tumblers . The second one that we just got wants to start the car as soon as the key is turned to the on position without turning it to the start position. Anyone know how to bypass the switch to see if it is the switch internals that are defective ? The wires are purple for solenoid , black for battery , double pink for accessory ,brown for ignition 1 , and dark green for ignition 2 . It's a new wiring harness and all of the wires are on the correct terminals.
Several things could be causing this. First, your 57 uses an ignition switch (1116512) which is unique to 55-57 cars and their wiring harness. I am wondering if you may have gotten a generic replacement that is responsible for what you describe. You can confirm the correct operation of the switch itself by removing the lock cylinder and using a flat blade screwdriver inserted in the D slot of the switch check and see if it will function correctly now. That will also rule out a problem with your lock cylinder as well. I think it is most likely you have the wrong switch or something is wired incorrectly. Pilot Dan
ps. If it were my car, I would get an NOS or good used GM original, plenty out there.
I just received the switch from ebay and I need to know if there are supposed to be part numbers on the switch itself . The part numbers on the DelcoRemy box are correct but the box was opened and there are no part numbers on the switch . The switch looks and acts like the import . Could this be a switcharoo by the ebay seller ? Should there be part numbers on this switch ?
2023 C1 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared))
2019 C1 of Year Finalist (track prepared)
Here's an original switch housing:
There is a 512 on one side, and what appears to be an 11 on the other side. No other numbers are visible.
bj1k (07-14-2016)
On the back in very small letters it says:
Delco
Made in USA
Remy
The lettering is in a circular pattern. Sorry for the crummy photo.
Delco
Made in USA
Remy
Thanks for that Todd . It does have the 512 and 11 on the other side . The DelcoRemy insignia is on there but I would have never known if you didn't point it out . Had to go outside with a magnifying glass and I could barely make it out. The pictures really helped . Thanks Again
It is time to get a large color wiring diagram and re check the routing and connections between the switch and the other ends. IIRC there are 2 pink wires that look similar which both go to the ignition switch. Just a quick thought on what to try next.
