how to test dash dimmer on 64
anyone can guide me how to do that with only the dash harness hooked up (and not connected to the engine compartment harness). I tried to follow the instrument panel wiring diagrams but no succes yet. I tried to measure variable resistance but could not find it...What I need is the feed wire (on the fuse box side) for 12V that goes to the dim resistor in the light switch
The voltage comes from the fuse box on the brown wire of the tail light fuse (second from bottom). It goes through the dimmer rheostat and then up to the instr lamp fuse (third from bottom) on the dark green wire.
If you pull those two fuses and measure between the right side of the tail fuse clip to the left side of the instr fuse clip, you'll be measuring only the rheostat resistance.
You don't really have to pull the fuses, I just like to isolate other possibilities when measuring resistance. It should read the resistance with fuses in place.
alexandervdr (07-26-2016)
In which lead can I add some extra resistor for the dash lights? My best guess is the (grey) lead on the 'right' side of the in instr fuse ?
I have no experience with LED's, but if all you want is to add resistance to the bulb circuit, either in line with the dark green to the fuse or with the gray where it comes out of the fuse box before it splits to the bulbs. In other words, in SERIES with the instr lamp fuse.
Yes, please send the link through. Tnx
