[C2] Replacing 67 headlight bulbs
And, then the three retainer ring screws behind the facia that you will be removing. Work the socket gingerly off the back of the old bulb...it may be stuck. Pull from the socket NOT the wires. Apply lightly some dilectric grease to the prongs of the new bulb. 10 minute job.
If you need to adjust your headlights, I would recommend having some of the plastic adjuster stands on hand. After 49 years, they’re brittle and you’ll probably break a couple of them. https://www.paragoncorvette.com/p-35...pport-kit.aspx
