67 Steering Column Harness
Looking for some direction on how to route the steering column harness connections to the main fuse panel pigtail harness. UPC 12 Ref B3 is the only sheet in the AIMs that I found that is related and is not very clear or easy to follow. Does the harness route under or over the clutch rod? Where does the clip on the connector fasten to? Appears to me, based on the AIMs that the turn signal switch is routed over top the column and then connected to the pig tail harness to keep the slack harness up out of the way, would my assumption be correct? Thanks for any help, if you have a pic that would be wonderful. Steve
