1954 corvette ignition lock
On a 54 Corvette with the stock ignition switch is there a way to remove the tip of the ignition (the part you touch with your fingers to start the car) and will it fit on a aftermarket lock cylinder. Thanks.
Received 6,528 Likes
C2 of Year Finalist (track prepared) 2019
I don't know the answer but I am curious about why you want to use an aftermarket switch. Is there something wrong with the original switch?
The actual switch seems to be working ok. I messed up the ignition lock cylinder trying to re key it. I like to look of the tip of the original ign. cyl. lock and have seen the individual tips on ebay. I just do not see how they come off. Thanks.
