[C2] Coolant "keg" question.
Have a 1966 Vert 327/300. How much coolant is supposed to be inside the coolant keg? Mine is about half-empty (or half-full, depending on your perspective). I ask because I discovered some coolant on the floor and sprayed inside the fan shroud. Car seems to run ok.
Thanks in advance.
Thanks in advance.
half...yours is correct...run it this level and if it still pukes, you need to find out why your car is puking out fluid...
PrimeRib (11-01-2016)
Yes...its ON the water pump...
Received 6,943 Likes
2015 C2 of Year Finalist
The tank should have a line that states fill to that level when cold.
The tank being half full is just fine. If you have coolant leaks up front, its coming from some source other than the tank.
As stated, check the water pump - the weep hole is on the bottom, behind the shaft -, the hoses, and the radiator itself for leaks.
you must be a Brit.
In the USA it's an expansion tank.
we drink beer out of a keg.
Just as often as possible.
Welcome to our sanitarium.
I'm very American. But it still looks like a little keg. I live in a region in PA with many good breweries close by. Perhaps I am just showing my age?
I guess we could call it a pony keg - but then it would just sound like a Mustang.....
Received 1,843 Likes
Water pump leaks often show up with witness inside the back side of the water pump pulley.
