Grab bar cover help
Grab bar cover help
I decided NOT to replace the entire grab bar on the 62 only the cover. Seems like a reasonably easy job. However, when I removed the old cover the old foam had deteriorated in some places and looked like weatherstrip adhesive. So has anyone replaced the foam and what did you use? May have to send the cover back and go for the whole enchilada but would like to save a few $
Thanks.
Thanks.
You're kinda stuck if the foam has gone bad....it get a new bar or wrap it in some new foam -- which I wouldn't want to try and still get the cover on easily...
I'd suck it up and buy a new grab bar...
jcchevy (12-15-2016)
Also getting the cover on is a bear of a Job on a pristine bar (I actually just did one for the first time last night) this was after the nice people at Al Knoch may as well have laughed at me for attempting to do it on my own haha. After a bunch of trial and error I have found an easy way to get it on:
1. Flip cover inside out
2. fold seams flat and glue down.
3. put glue on first 1/2" or so of grab bar and cover (making sure not to get glue near the very edges)
4. fold the glued edge inward and start it over the grab bar.
5. Begin sliding the cover down the grab bar over itself (flipping it right side out over the grab bar) checking often to make sure the glued edge is not sliding down
6. When it gets too hard to slide down any further spray silicone down the vinyl side of the cover
May be sort of hard to visualize but using that method I could cover a second one in under 15 minuets I bet.
