Front disc conversion 64
Is this the m/s I need for 64 front disc / rear drum power brake conversion. Thanks
https://www.summitracing.com/parts/rsd-dbmc09
I didn't do the conversion on mine, but mine appears to be a single reservoir still. I don't know if it requires a dual reservoir or not. Sorry I wasn't much help.
Power or manual brakes? The bore is too large for manual brakes and your pedal will feel like pushing a rock with inadequate braking.
Don't go larger than 1" bore with manual and preferably a 15/16" bore.
Dave, there's a lot of discussion in this thread on master cylinder options.
https://www.corvetteforum.com/forums...onversion.html
Keep in mind, if you retain the rear drums you'll need to incorporate a proportioning valve regardless.
Good luck... GUSTO
Good luck... GUSTO
