[C2] Fan Clutch Removal
Fan Clutch Removal
I'm looking to replace the fan clutch on my '66 BB. I can remove 3 of the bolts securing it to the water pump, but what's the trick to get the 4th one out. It just rotates around. Where can I get enough leverage to break the seal on the bolt?
Received 1,533 Likes
I loosen all 4 before removing any of them.
Tried that, still stuck.
R66's method should have worked...perhaps soak the bolt with some PB Blaster or the like and let it sit overnight. Did the method not work because the setup still turns or you just can't put enough "hind end" into it to get the bolt loose ? Two different issues...
I bought a set of extended length wrenches (wimp wrenches) to aid me when my arthritis started limiting my pull. Also have used a piece of pipe over the end of the box end wrench to get more leverage. There is also the wrench on a wrench - putting a box end wrench in the open end of the first wrench to increase the length of the wrench.
I have also had a friend hold the wrench that prevents the fan shaft from turning while I used a hammer to strike the end of a good quality 6 point box end wrench firmly engaged on the bolt head to get the stuck bolt to turn. Warning: this method can damage the wrench, bolt head, generally the mechanic's hand, engine components, and anything else the hammer hits if the hammer is not accurately guided. Don't ask how I know.
Frankie
You are the man!. Im thinking of replacing my clutch and installing a 7 blade fan. What's the difficulty on the Frankie meter? To provide some background, I just replaced my Harrison tank that was super easy. I replaced valve cover gaskets easy. Replace carb; wire harnesses (except maybe engine harness) - I wouldn't even try. Hope that helps. I guess on the mechanic scale Im a 4. Much better with body work.
Just so frustrating when the parts are reasonable but the labor in NJ is absurd.
Thanks from one Frank to another!
Best
Frank
Best
Frank
For anyone taking off/putting on the fan, it is a neat trick to replace one of the four bolts with a short stud first. That way, the heavy fan will hand on the stud when the last bolt is removed (or the first one started). The makes it easy to deal with the remaining bolts while the fan is hanging on the stud instead of on your arm.
Lou
Lou
fjd (09-16-2019)
You can also push down hard on the fan belt. That way the crank pulley would also have to turn along with the water pump pulley. That's probably not going to happen to break the torque on a 5/16" bolt.
I just installed one using studs to keep both pulleys and the clutch in alignment. After I installed the fan belt, I pushed down on it and torqued the bolts down to 22lbsft.
Verne
Verne
Thanks!
Lou
Lou
Also makes it a lot easier upon reinstall
