Fine tuning spark advance with dwell angle changes
Old 12-24-2016, 09:02 AM
  #61
MikeM
MikeM's Avatar
Received 1,843 Likes on 1,398 Posts
I'll let you be the judge which is easier but there was full agreement on how to advance the timing and how to retard it and I avoided any indecision about what changing the point dwell would do.
Old 12-24-2016, 10:24 AM
  #62
426 Hemi
426 Hemi's Avatar
OK, ventured out to the sub-freezing shop and fired up the Sun machine.
Set dwell at 28º--then set the strobe pointer to 0º
Slowly adjusted the dwell to 32º. Pointer indicated 2º advance (EDIT wrong, retard is correct)---which I believe you double to get crankshaft degrees.
Old 12-24-2016, 10:32 AM
  #63
Critter1
Critter1's Avatar
Slowly adjusted the dwell to 32º. Pointer indicated 2º advance---which I believe you double to get crankshaft degrees.
Thank you !! So, I/we were right from the beginning. One degree of dwell change is ONE degree of timing change at the crankshaft.
Not 2° like the original poster stated.
But didn't the timing retard by 2°, not advance?
Old 12-24-2016, 10:38 AM
  #64
DansYellow66
Support Corvetteforum!
DansYellow66's Avatar
Received 2,616 Likes on 1,948 Posts
Well that kind of refutes the idea of why so many tuneups resulted in the car running so much better because the timing was retarded from point block wear and narrowing gap. And it seemed logical too.
Thanks for checking it. Love those old distributor machines. I asked down at our local speed shop the other day, if they still had theirs that I once had my TI checked on. They said they got rid of it a few years back. Too bad.
Old 12-24-2016, 12:42 PM
  #65
survivor66
survivor66's Avatar
I don't know these machines but is it possible an accidental reverse polarity connection would change a correct retard reading to advance? Rotating the opposite direction would do the same but I doubt the machine has that capability.
Old 12-24-2016, 01:08 PM
  #66
426 Hemi
426 Hemi's Avatar
Hey guys, my screw up.
When going from 28º to 32º the strobe pointer moved to the left of the zero---which is retard.
(When spun up and the centrifugal kicks in the pointer moves to the right---advance.)
Again my bad. I'll take the D- on the report.
Old 12-24-2016, 01:13 PM
  #67
MikeM
MikeM's Avatar
Originally Posted by SWCDuke
I can be tricky to intuit, but increasing dwell reduces point gap, so they close later and open earlier and vice versa for decreasing dwell. It's points opening that triggers the spark.
Duke
Increasing dwell let's the points close earlier and open later.
Old 12-24-2016, 01:30 PM
  #68
Critter1
Critter1's Avatar
Yup, absolutely right.
Is everyone on board with us now?
Where's Duke? He started all this.
He posted the exact same thing over at the NCRS board too but no one corrected him yet.
Old 12-24-2016, 02:38 PM
  #69
MikeM
MikeM's Avatar
Quick, check the Cosworth Vega site! Oh wait, they don't have points, do they.
Old 12-24-2016, 03:11 PM
  #70
Powershift
Powershift's Avatar
Received 1,681 Likes on 1,307 Posts
Glad we got this straight and agreed to in print. Many of us have KNOWN this fact for over 1/2 a century. Years ago many (like myself) played with dwell, points replacements/changeouts, and timing (incl power timing) just about every weekend. Some things you just don't forget, no matter how old you are.
Larry
Old 12-24-2016, 03:48 PM
  #71
SW Vette
SW Vette's Avatar
C2 of Year Finalist (stock) 2019
2018 C2 of Year Finalist
Since it was my car Duke and I were playing with in the first place, I guess I'd better go recheck my timing now - it may be retarded a degree or 2.
Old 12-24-2016, 04:29 PM
  #72
DansYellow66
No problem - we are back to where things make sense again.
426 Hemi (12-24-2016)
Old 12-24-2016, 06:28 PM
  #73
MikeM
MikeM's Avatar
It is Paul Harvey time!
Old 12-25-2016, 04:12 PM
  #74
MikeM
MikeM's Avatar
Well?
Old 12-25-2016, 08:23 PM
  #75
Critter1
Critter1's Avatar
Well?
Still no reply from Duke?
Old 12-25-2016, 08:30 PM
  #76
SW Vette
SW Vette's Avatar
Well?
Did it the lazy way - a seat of the pants check - car runs great!
Old 12-26-2016, 10:44 AM
  #77
SWCDuke
SWCDuke's Avatar
Received 1,973 Likes on 1,188 Posts
Sometimes we make mistakes. The owner was working the Allen wrench and reading the dwell meter while I was working the timing light. It appears that one or both of us either didn't follow the test plan correctly or misread the equipment.
It would help if someone else would run the test on a car. This thread, as of this writing has nearly 2500 views and 76 replies, and you are the only one to lend a hand. Thanks for taking the time.
Duke
To Fine tuning spark advance with dwell angle changes
Old 12-26-2016, 11:18 AM
  #78
Critter1
Critter1's Avatar
Duke
It wasn't necessary for me to do a test. I knew what I was talking about from the beginning of this thread.
I hope you go over to that other place and straighten that out too. Most of those guys believed you.
  #79
PAmotorman
PAmotorman's Avatar
if you want to adjust your timing without a timing light and know where you are just convert the vacuum advance to a threaded rod and knowing the number of threads per inch you can calculate the number of turns gives you what degree change. I did this on some short track and drag race engines.
Old 12-26-2016, 11:24 AM
  #80
PAmotorman
PAmotorman's Avatar
any time you increase the dwell the points stay closed longer and open later and that is when the ignition fires. the ignition fires when the points open
Quick Reply: Fine tuning spark advance with dwell angle changes
