Tire/Wheel Combo Question (TT II)
Old 01-27-2017, 05:47 PM
ike2010
CF Member
Default Tire/Wheel Combo Question (TT II)
Greetings. Searched the forum, and found some help, but nothing absolute. I'm in the market for new wheels and tires. 1965 convertible here. Has anyone had experience with either of the following setups?
Option A (preferred):
18x8 Torq Thrust II
225/50R18
These wheels have a 4.50" backspace
Option B:
18x7 Torq Thrust II
Tires TBD
These wheels have a 4.25" backspace
Main concern is the backspacing at this point, so curious if anyone else on here has seen these wheel/tire combos. Thanks.
ike2010 is offline
Old 01-27-2017, 09:13 PM
Mikado463
CF Senior Member
Support Corvetteforum!
Mikado463's Avatar
no but I am using Torq Thrust II's (17 x7, 4" backspace) with 225/55-17 tires FWIW .......
Mikado463 is offline
Old 01-27-2017, 10:18 PM
DJordan442
CF Senior Member
DJordan442's Avatar
These are on my 67. If you like the set-up I can check into the dimensions. Loads of compliments even from old ladies
DJordan442 is offline
Old 01-28-2017, 01:25 PM
ike2010
CF Member
Beautiful. Thanks for the info. I was thinking I'd have to go to 17". Looks great.
ike2010 is offline
Old 01-28-2017, 01:30 PM
ike2010
CF Member
So nice! If I read that correctly, those are 225/50R17, which is slightly different that Mikado's above "(17 x7, 4" backspace) with 225/55-17". By the looks of it, I'm guessing that the wheels are the same, and it's just the sidewall height that is slightly different. Either way, if you have the information handy, I would love to know what size those wheels are and what the backspacing is. Between these two, it looks like I have exactly the information I was hoping for.
ike2010 is offline
Old 01-28-2017, 02:33 PM
Mikado463
CF Senior Member
Mikado463's Avatar
Ike, for the record my 225/55-17 will place you almost perfect to stock height tire dimension whereas 225/50-17 will be off enough to notice on ones speedo
Old 01-28-2017, 04:18 PM
DJordan442
CF Senior Member
DJordan442's Avatar
The receipt is hard to read but looks like the wheels are 17x7 Torq-Thrust 2.1 with 4" backspace. Tires are 225/50/17. It does sit a bit lower than stock but I like that. I can measure the difference between these are the stock times I have if required. Good luck
Old 03-13-2017, 02:53 PM
ike2010
CF Member
Went with the 17x7 and 225/55/17. Love it. Replaced all rubber suspension bushings, put on new Bilstein shocks, and sandblasted/painted suspension while I was in there.
ike2010 is offline
Quick Reply: Tire/Wheel Combo Question (TT II)
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
