Fiberglass Repair (C1 Hood Support)
Old 01-29-2017, 10:11 AM
Hermn59
Support Corvetteforum!
Hermn59's Avatar
Default Fiberglass Repair (C1 Hood Support)
Hello, the fiberglass where my hood support is mounted to the fender is cracked, and it flexes just with the weight of the hood. I am looking for advice on repairing this area before it becomes a bigger problem. Anyone dealt with this before?
Old 01-29-2017, 10:39 AM
hedgehead
hedgehead's Avatar
Location: I'm not doing as well as I expected, but I never expected I would
After you make repairs, you may want to install this:
http://www.parts123.com/corvettecent...50e&ukey=43579
Hermn59 (01-29-2017)
Old 01-30-2017, 09:26 AM
csherman
csherman's Avatar
Received 1,421 Likes on 734 Posts
C1 of Year Finalist (stock) 2019
2018 C1 of Year Finalist
what year?
Old 01-30-2017, 09:45 AM
Hermn59
Hermn59's Avatar
Default 1959
Originally Posted by csherman
what year?
This is for a 1959.
Old 01-30-2017, 10:07 AM
csherman
csherman's Avatar
the brace will work, but is not "correct" - if you dont care about correct......
The other thing you could do after repairs is cut a rectangle of fiberglass and bond to the underside to try and give that area strength - then use longer bolts for the hood prop
Hermn59 (01-31-2017)
Old 01-31-2017, 03:05 AM
Hermn59
Hermn59's Avatar
The brace states 1960-1962, so will it work on the 59?
Old 01-31-2017, 07:32 AM
Steve59
Steve59's Avatar
Yes, I have one on my 59.
Old 01-31-2017, 10:22 AM
jimh_1962
jimh_1962's Avatar
sure will work on 58-1962
Old 01-31-2017, 09:29 PM
HilltopClassicCars
HilltopClassicCars's Avatar
My wife's 1960 didn't have this brace or anything else in its place and I couldn't believe how far the edge of the fender bowed down when the hood was up (this is when we went to purchase the car). I was surprised it hadn't already broken the fender and immediately asked the seller if we could close the hood and then the first thing I did when we got the car home was duplicate the brace shown in the link above out of some 3/32" sheet steel. What a difference that brace makes!
Hermn59 (02-01-2017)
Old 02-01-2017, 10:44 AM
jimh_1962
jimh_1962's Avatar
I installed the same brace. It really does help.
Old 04-15-2018, 09:58 PM
sebc
8th Gear
sebc's Avatar
Hi, do you have the actually part number for the pictured brace/bracket. Link attached doesn't work for me and I can't seem to locate part on CC?
Old 04-15-2018, 11:05 PM
CANDA
CANDA's Avatar
60-62 Hood Support Reinforcement
SKU 461115
$35.00
sebc (04-15-2018)
Old 06-13-2022, 02:08 PM
jackham
3rd Gear
jackham's Avatar
Are there any clear instructions on how to mount the brace and where? Could any of you that have put one on the left hand side provide some pictures? I can't seem to find anything but the one picture here and it doesn't really resemble the one I got from the parts supplier. Thanks for any help.
Last edited by jackham; 06-13-2022 at 02:53 PM. Reason: Needed to add more to the question.
To Fiberglass Repair (C1 Hood Support)
Quick Reply: Fiberglass Repair (C1 Hood Support)
