[C2] Bench Testing Headlight Motor??
I have rebuilt the headlight motor on my 66. I'd like to bench test it first. How would I connect my hot wire/ground to test it? I'd like to test both directions. The connector has two pins. Anyone done it before? Thanks.
Exactly right....its a pretty low-torque setup...it won't 'buck' like bench testing a starter motor, etc.. If it doesn't run similarly in both directions you might want to adjust the end play (you'll see the adjustment lock nut)...
