hood latch 57
hood latch 57
i just received a right side hood latch for my 57 and it has the arm on it for the brake cable . is this right my car has the arm on the left side. just has the hole on the right side ( passenger side) thanks zano
on the passenger side the cable is off to the side and requires a arm pointing outboard.
Brake cable ??????
Received 1,435 Likes
C1 of Year Finalist (stock) 2019
2018 C1 of Year Finalist
I think you mean hood cable
the bodies are the same but the "arms" are a little different
LH is a straight down
RH is a right angle
Normal
RH is a right angle
Normal
on mine it is a straight pull on passenger side and the latch mounted on the fire wall on the drivers side has that little arm attached to it with a hole at the end for the cable. it's backwards. but if i reverse them the cable won't line up with the hole.
exactly as they should be......
RH side has an arm
LH side does not
Nice original TR bolts !!!!
http://www.parts123.com/corvettecent...50e&ukey=43547
RH side has an arm
LH side does not
