rear housing build dates
C2 of Year Finalist (stock) 2019
my buddy is trying to find a rear housing dated properly for his car. there are tons out there and i get confused talking to him about it. his car is a may 15 65 car i believe he told me. i understand that a housing prior to may, like a jan feb march april. but really how far back is realistic? and how close too the car build date could it be stamped? thanks guys troy
Larry
20round (03-29-2017)
thanks larry, so then for instance may 15th, should be a end of april stamping on the housing? he has found one housing that was 4 days before his build that had a 355 gear in it. that is the gear he is thinking about. but i thought it might be too close to his build date? thanks for the imput..troy
And I KNOW my rear axle is original to the car.
Larry
EDIT: Corrected rear axle date.
Received 1,857 Likes
You might point out to your buddy that the "numbers" on differentials aren't judged in NCRS Flight Judging - only the external configuration.
thank you JOHNZ! it is good too see you back! thank you for the info. he is just making sure nothing is out of the norm for his car if he did decide to do somthing with it..thanks again troy
The rear gears for the C2 cars didn't sit around very long. My 1967 car was built on March 28, 1967. (It just turned 50 years yesterday ) My rear gear housing is stamped May 23, 1967...............a difference of only 5 days.
Larry
Larry
Assz
Larry
Larry
Larry[/QUOTE]
Larry, I'm sure you meant March 23.
My 67 build date was Feb. 24 (Friday car). My housing date was Feb. 21.
Bob
Larry[/QUOTE]
Bob
Bob[/QUOTE]
Bob:
Thanks for the correction. You are correct..........the rear axle build date was March 23, 1967 and not May 23, 1967. I made the correction in my earlier post above.
Larry
