My Daytona Blue '64 Coupe
#202
for sure.
I'm really enjoying this thread. Mainly because you're making a really nice '64 coupe your own. I have to agree most people won't get the plaid interior but people who are real enthusiasts will know that Porsche was not bashful using plaids in even their most serious road carving machines. Keep the updates coming.
#203
Thats actually my Brother-In-Law's '67 Camaro. Fun story, we looked at that car and he bought it the morning of my wedding in Austin TX. He and I flew back two weeks later to pick it up and drive it home.....made it an hour outside Austin before the 396 seized. Real nice car that was well taken care of but rarely driven. Now its got a crate 454 in it and absolutely annihilates tires. My two nieces love going to Cars and Coffee in it.
#204
for sure.
#205
On to the front.....the last remnants of the drum brake system are gone!! I do need to run to the store to grab an inside spring compressor and a fork to pop the ball joints before I go any further.
On to the new stuff. As stated earlier, I'm using Wilwood D8 calipers and a 15/16 master cylinder. Initially, the intent was to limit suspension mods to a 13/16 sway bar with poly bushings, some Ride Tech/Fox Racing single adjustable shocks, and Global West's "Del-a-lum" bushing for factory upper and lower A-arms. After some research, I realized that you have to do some modifying/welding on the factory A-arms in order to install the Del-a-lum bushings. I wasn't interested in that as I have zero welding experience, and one of my big sticking points with this car is that everything can be bolted back on if I ever want to go back to 100% factory original (with the exception of that rear bump stop mount that I had to cut....that would require welding a new 63-64 mount to the frame). So the solution was to order Global West's upper and lower control arms. They are a bit spendy, but in this case, you definitely get what you pay for. High quality pieces with what should be a straight forward install. The rest of the stuff is factory '65-'67 bits from Van Steel. I did hit the sway bar, spindles and arms with VHT chasis black to prevent any corrosion. More to follow....
#206
Wheels!
The two test wheels I ordered from Summit Racing showed up today. I'm really trying to keep this car on 15" wheels and run a 225/60/15 Avon CR6ZZ tire for the vintage race look.
The first wheel I ordered is the American Racing Torque Thrust D. 15x7, 3.75 inch backspace, 5x4.5" bolt pattern. Bolted up beautifully with my long style lug nuts from Vintage Wheel Works. They clear the brakes just fine, my two concerns are that with the 3.75 inch backspace, it looks like the wheel lip is going to be just in line with the fender lip....add the tire bulge, and I'm a little concerned about the potential for contact going over a bump in a turn. Obviously the suspension is unloaded in this pic, so theres huge positive camber, but once its all dialed in, I'm still wondering if its a little close. Second, you can also see its pretty close to the leaf spring on the inside once you take tire bulge into account. I don't really want to go to 17's, but at that size, I could run a 4" backspace which would solve both problems....it would pull the wheel in from the lip ever so slightly, and the spring end would be inside the circumference of the wheel.
The second wheel I ordered is Trans Am Racing's Superlite in 15x7, 4.0 inch backspace, 5x4.5" bolt pattern. I really like these wheels, and think they would look great on the car, but unfortunately, they won't even bolt up. I can't get them over the wheel studs. It looks like the holes are just slightly off the 5x4.5" bolt pattern. In the one pic below, you can see how chewed up the holes are in the back of the wheel. Its interesting because both wheels are manufactured in China, but the AR wheel appears to be significantly higher quality.
Any input on 3.75 vs 4.0 inch backspace on the 15x7 wheel would be greatly appreciated. Or on 15s vs 17s. I'm kind of up in the air at this point.
#207
Received 5,547 Likes
5x4.5? Standard Chevy is 5x4.75. Isn’t that your spacing?
i have the torque thrusts on my ‘64 and really like them.
#208
Received 1,919 Likes
Greg;
I also have an inside spring compressor set and a pickle fork.
Love what you're doing, BTW.
Kevin
Kevin
#209
Much appreciated Kevin....I grabbed a pickle fork from the store today, and ordered an inside spring compressor that should arrive tomorrow. Probably good tools to have on hand.
#211
#212
IMCO I think the TTD looks perfect but...…….at the risk of starting a fire storm the fit is too tight. I know you don't want to go to 17s but there's more advantages over the 15s. Besides more tire choices (50 series and even 55 series sidewalls which will not look like "rubber bands") wheel backspace options are better. You can run more backspace. You can go 4" or probably even 4.25" backspace. Other opinions will vary for sure but it's always better to error on more backspace than less as a small thin high quality spacer can give you that little bit of extra clearance if needed. If you error on not enough what are the options? Narrower tires, higher ride height, reorder the wheels, or worse cracked fenders. Also whether you go with 15s or 17s there's other options besides the A/R TTs. You can also look at Team III E/Ts and Vintage Wheel Works which you already know. I hope this helps.
#213
This is the path you have chosen to travel. Embrace it. Confucius
#214
I use this KD compressor, but with only the top hooks. For the bottom I use a square of 1/4" plate with a hole punched in it, placed over the shock hole. So you're pulling the top of the spring down toward the lower A-arm.
You'll notice the hook arms are different lengths. If you place the shorter arm higher, the spring will compress into a slight curve, which helps clear the upper pocket.
Don't forget to lube the threaded rod... Good luck! Mike
FLYNAVY30 (09-08-2018)
#216
BTW, I built a database of posts of folks who successfully use 235s and 7” rims. If interested I can email.
#217
The 15x7 with 3.75” BS wasn’t even close to working on the 4 C2s I put some new wheels on. The wheel distributor said 7” and 3.75” was normal. Wrong. He must have remembered 6” rims. I double checked the BS and outside dimension (~8”). Hard to imagine moving the rim in just .25” is enough. Last Thursday ordered new wheels with 4.5” BS to match LouieM and others. I’m be moving the ebrake mount. Ordering one wheel at a time is smart. Best wishes.
#218
My Favorite is
Well, we finally made the trip to Mershon's this past weekend to pick up the car and it didn't disappoint. As some may have seen in my WTB posting, I was very specifically looking for a 1964 Daytona Blue coupe with the solid lifter 365 horse motor and a 4 speed. The only additional options this car was ordered with is the two tone blue/white interior, off road exhaust, 3.70 rear end, and for an additional $10.80......reverse lights.
Mershon's was excellent to deal with and having Pancho Thompson inspect the car prior to the sale was money well spent. I actually got to meet Pancho when we picked the car up as he was back at the shop doing another inspection. Thanks Pancho!
The car came with a photo album full or restoration photos and a box full of documentation which includes owner history and registration numbers dating back to the build and delivery date in February of 1964, all 1964 sales materials and original owners manual, all NCRS and Bloomington Gold documentation and judging paperwork from 1982, and even the gold lapel pin. The short summary of the history is that the car was given a full frame off restoration between 1979 and 1982.....the owner at the time maintained copious notes and photos. It was especially cool to flip through his log and see what parts were purchased and installed, and how much time he worked on the car on Dec 19, 1980....which was my birthday. At the time of the restoration, the odometer was reset to 0 miles.....it currently shows 329 total miles. Apparently it has been sold a few times and most recently sat in someone's collection who was forced to sell due to divorce, which is how Mershon's came on the car.
Now that its done its time on the show/garage queen circuit, its going to be driven as often as possible. Ill be sure to continue the detailed maintenance log of the prior owners, but I have no intention of babying the car. Things will be fixed/upgraded as necessary. My plan is to keep the car relatively original, but as things break, if there's a better option on the market (65-67 disc brakes, etc.), Im not going to sacrifice durability for originality. That being said, any original parts removed will be carefully documented and stored for future potential restoration (not really my thing, but Im also not so naive as to think personal taste and interests don't change over the years).
With all that being said, please enjoy the pics of our adventure below, and check back often as Ill be continuously updating this thread as I drive, break, fix, and enjoy the car.
#219
And another one bites the dust
As you know I think they are utterly unnecessary, and as such, the original seats remain in my 64. But, that is irrelevant to you, because you want them, and you are the decider when it comes to your car. Duh!
That said, they look great! If I were going to change out to utterly unnecessary up-scale seats, those are what I would choose.
#220
