My Daytona Blue '64 Coupe
Old 06-24-2019, 08:09 AM
  #561
FLYNAVY30
CF Senior Member
FLYNAVY30's Avatar
Yup, car is at ride height.
FLYNAVY30 is offline
Old 06-30-2019, 06:11 PM
  #562
FLYNAVY30
CF Senior Member
FLYNAVY30's Avatar
While I continue to unsuccessfully wrestle with my rear wheel alignment, I thought some of you would appreciate this.....
I grabbed this tailgate at a local estate sale almost a year ago....mostly because it was cool and cheap. I think its from an early 50's 3100 series truck, but I'm sure someone more educated than I can fill me in. We have a local pinstripe artist who is very talented here in Virginia Beach, and I've always wanted to have him paint something for me, but neither of my cars are really of the style that warrant pin striping, lettering, etc. but I figured this tailgate was the perfect thing to let him go nuts on as I just wanted a cool piece to hang in my garage. So I dropped it off a few weeks ago and told him to do whatever he would do if he was going to hang it in his shop. Needless to say, I love it. Being an equal opportunity car guy, I like how he worked in the logos of the "Big 3" as well as the old school hot rodding influences of Ed Roth. Also, given that we live in Virginia Beach, I love the ocean/beach horizon he used in the "CHEVROLET" lettering.
Anyway, just thought some of you would appreciate it....I've done some more research, and at least have a few things to look at with regard to the rear toe issue on the car. More to follow.
The following 8 users liked this post by FLYNAVY30:
3JsVette (06-30-2019), Easy Rhino (07-01-2019), elwood13 (06-30-2019), leif.anderson93 (07-01-2019), Mike C#2 (06-30-2019), tf104 (07-01-2019), Tool Hoarder (07-01-2019), USMC 0802 (07-01-2019)
Old 06-30-2019, 07:26 PM
  #563
rtruman
CF Senior Member
rtruman's Avatar
I know that part 57 Chevy Truck .My new addition after the 63 Corvette,
rtruman is offline
Old 06-30-2019, 09:35 PM
  #564
3JsVette
CF Senior Member
3JsVette's Avatar
I like it! He's very talented. The Chevrolet logo and Ed Roth influence look great. Nice wall art.
3JsVette is offline
Old 07-01-2019, 07:46 AM
  #565
smacota1
CF Senior Member
smacota1's Avatar
Better watch out.....Frankie the Fink might grab this one off the wall when you are not looking.
I LIKE IT!
smacota1 is offline
Old 07-01-2019, 11:45 AM
  #566
uvettcha
CF Senior Member
uvettcha's Avatar
right when you think youve seen it all.................hi.....
uvettcha is offline
Old 07-09-2019, 05:01 PM
  #567
FLYNAVY30
CF Senior Member
FLYNAVY30's Avatar
Well, still trying to eat the elephant one bite at a time....currently have 3 major road blocks:
1. front sway bar....13/16 poly support bushings don't fit in the stock mounting brackets. I found an NOS rubber pair on ebay, those should be here this week. If that doesn't work, I've got the poly bushings in the freezer which I will shave down until they fit properly.
2. still haven't figured out my issues with the rear alignment.....may just bite the bullet and trailer it up to Zip Corvette outside of Richmond once I have everything else sorted
3. while attempting to push the car up and down the driveway a few times to settle the suspension and readdress the rear alignment, realized that I still have a relatively soft brake pedal. This makes no sense to me as I bled the ever living hell out of the system, and its about as simple a brake system as you can get.
More to follow
Old 07-10-2019, 05:14 AM
  #568
roadster65
CF Senior Member
roadster65's Avatar
Originally Posted by FLYNAVY30 View Post
Well, still trying to eat the elephant one bite at a time....currently have 3 major road blocks: - More to follow
Small steps; each one brings you closer to "home" - GV
roadster65 is offline
Old 07-10-2019, 05:31 PM
  #569
FLYNAVY30
CF Senior Member
FLYNAVY30's Avatar
Finally splurged for a Quick Jack BL-3500SLX.... the *** pain of the jack/jack-stand dance in my very narrow garage has finally pried my wallet open after seven years of renting in this condo...should be here Monday. I'll try to get the brakes sorted and the sway bar installed this weekend, and then get back after the brakes after I get the Quick Jack set up.
Tool Hoarder (07-11-2019)
Old 07-10-2019, 06:10 PM
  #570
elwood13
CF Senior Member
Support Corvetteforum!
elwood13's Avatar
Thatís the one I got and use it on everything but the tundra.
Edit: I got the 5000slx.
elwood13 is online now
Old 07-10-2019, 06:39 PM
  #571
FLYNAVY30
CF Senior Member
FLYNAVY30's Avatar
Yea, I've wanted one for a while now, but always viewed it as a luxury item, but with the number of times I've had this car on and off stands, its probably a good investment. The terrible creaking noises these things make as you jack them one point at a time is also a little unnerving.
On the plus side, I've found a lot of good info over on the C3 board about bleeding this system (specifically the Wilwood calipers). Apparently, despite bench bleeding the master twice, I need to tilt the car forward (*** end high) in order to get the last bit of air out of a new master. Theres some pretty good videos posted covering the subject as well. I believe that's likely my issue as the pedal goes to the floor on the first pump, but on the second pump, I'm back to having a firm pedal. Heres hoping!
Old 07-10-2019, 06:43 PM
  #572
leif.anderson93
CF Senior Member
leif.anderson93's Avatar
You're going to love your new Quick Jack. I opted for the 5000SLX...a bit more piece of mind and not that much more money.
leif.anderson93 is online now
Old 07-10-2019, 06:46 PM
  #573
FLYNAVY30
CF Senior Member
FLYNAVY30's Avatar
Yea, I thought about the 5000, but without driver, I'm sitting at just under 3100 lbs, and given my space constraints, I wanted the lightest, most maneuverable unit that would fit the bill.
Old 07-10-2019, 06:50 PM
  #574
Fat Mike
CF Senior Member
Fat Mike's Avatar
Love the tailgate! What a great idea for garage art!
Fat Mike is offline
Old 07-10-2019, 07:06 PM
  #575
FLYNAVY30
CF Senior Member
FLYNAVY30's Avatar
Thanks....I was very happy with it. When we finally move to our house in Austin, the idea is to use it to cover a recessed bourbon storage area in the wall....flip it down, and you'll have a little garage bar...flip it up, just looks like wall art.
He's doing another piece for me...I have a complete tail rotor blade from one of our helicopters that burned to the ground in 2014 (nobody hurt). He's doing a gold leaf/ pin stripe rendition of the Naval Aviator's wings on it for me. I'm very excited to see that hanging in the garage as well.
USMC 0802 (07-10-2019)
Old 07-11-2019, 09:44 AM
  #576
Tool Hoarder
CF Senior Member
Tool Hoarder's Avatar
Received 2,758 Likes on 1,425 Posts
I need to get one of those. Don't need a full lift for most work and tired of doing the jackstand roll around myself.
Tool Hoarder is online now
Old 07-11-2019, 11:19 AM
  #577
elwood13
CF Senior Member
elwood13's Avatar
Costco used to carry the 5000slx for $1099.00.
Greg, I’m just going to push them in towards the center of the car for storage.
Old 07-11-2019, 12:10 PM
  #578
leif.anderson93
CF Senior Member
Greg, Iím just going to push them in towards the center of the car for storage.
That is exactly how and where I store mine...easy peasy.
Old 07-11-2019, 06:26 PM
  #579
Factoid
CF Senior Member
Factoid's Avatar
Bourbon?!
Now Iím definitely coming over!
Factoid is offline
Old 07-11-2019, 06:31 PM
  #580
FLYNAVY30
CF Senior Member
FLYNAVY30's Avatar
oh yes, all of the Bourbons my friend! Theres a single bottle of the Garrison Brothers "Cowboy Bourbon" cask strength thats been sitting on the shelf at the NEX mocking me for the last few weeks...$184.99 is steep for bourbon....but still.......
The following 2 users liked this post by FLYNAVY30:
Factoid (07-12-2019), Mike C#2 (07-12-2019)
Quick Reply: My Daytona Blue '64 Coupe
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
